  • June 22, 2025, 03:08:59 PM
Author Topic: OS MAXS-35  (Read 1089 times)
Offline John Craig
OS MAXS-35
« on: January 12, 2014, 05:55:51 AM »
I have an eBay OS 35S  that has average compression, no visible external damage, crankshaft seems to be OK, appears to run true & has average vibration at launch RPM.  Let this engine get a bit to rich dropping in RPM  & it shakes as no other.  The tip of the spinner is spinning in an oval. It makes a Fox seem like an ultra smooth machine.  Makes little difference what balanced prop I run.  The fuselage is as firm as I can make it.  It will be a parts engine now!
What is the possible cause?  Slight imperceptible bend in Crankshaft?  Which part is bad?
Online kenneth cook
Re: OS MAXS-35
« Reply #1 on: January 12, 2014, 06:53:01 AM »
                John, your not mentioning what type of fuse your dealing with. I'm assuming this is a profile? Most profiles are susceptible to the shakes this one being the same. It might be a worn out crank bushing. However, some of my best runners literally had the crank wobbling in the case and they ran flawlessly although fuel was coming out of the front of the bushing.  I've had issues with this engine as well due to using too much oil. While many on here suggest using up to 29% oil content in the iron piston engines, I found for me 23% was my choice. Even when I used Sig 25% the engine would just run rough and quit typically at the worst time.   It certainly sounds as if once the rpm's drop the harmonics begin. What happens when your try and run the engine in the higher rpm's? Does all smooth out? For instance, if your running a 10x6, would a 10x5 fix this? Is the fuel fresh? I would also look at trying another plug that's hotter or better quality than the current one in the engine. The MAX-S is typically a sewing machine, I've had some shakers but this was due to lite ply doublers on the plane or crash damaged planes. With the plug out, you should be able to verify if the crank is bent just by rotating it. Is the drive washer fully seated with no dings or flaws preventing it to seat square on the shaft?  If the crank is that  bad, it will visually show up. Lose your spinner and put the prop back on and run the engine.  Even a prop regardless of balance may not have it's back mating surface parallel to the front bolting surface which will reveal the same appearance of a bent crank. Ken
Offline John Craig
Re: OS MAXS-35
« Reply #2 on: January 12, 2014, 11:16:21 AM »
 Ken,
The fuselage is as stiff as any I have & my Foxes do not give me trouble like this.  Fuel is 12-12-1-10; Fox, Enya, & McCoy run fine.  The props APC, MA, WOOD, & pitch make little difference.  Fox Gold R/C plug.  Bushing is not worn & no side play can be seen.   No spinner, just an aluminum Dubro spinner prop nut.  Seems fine at normal launch RPM but miss the needle on the fat side & have it drop into a very deep 4, then you can feel the vibration in the lines & a much further loss of power.  The local expert can not detect a bent crankshaft.  I am sure it is an engine problem. I will know next time I fly for sure as I have mounted a different OS 35S on the plane.  This engine is now a parts engine.  I interested in finding out what part is bad with out investing a great deal of time.
Re: OS MAXS-35
« Reply #3 on: January 12, 2014, 12:22:42 PM »
Hi John,
Did you get my PM?
