I hear what you all say and you bring up an interesting point on the venerable Testor McCoy Red Head engines. Out where I live, the nearest home to the flying field is a farm house a quarter mile away, next about a mile. A quarter mile oval dirt track is next door. I can fly without mufflers and my restored S-1 Ringmaster .35 RH will fly without it. Otherwise it would be nose heavy. Flying close to the ground, noise doesn't travel as far, too.
I've looked at the muffler issue, because it is possible that I may fly one of these days where it is required. A simpler issue, I'm thinking that I ought to build some CL planes that use muffled engines to begin with.
Since I have several .35 RH's, once I wring out the S-1, will try the larger Tatone .45-.65 Peace Pipe on it. It is large chambered and has a 3/8" dia. exhaust exit with a 1/4" dia. aperture ring just inside that can be drilled out. It weighs 2.3 ounces.
The RH's are really nice running engines and I am very pleased with them. From all and various inputs, I gather that similar to the K&B Sportster Schneurle chrome plated aluminum piston running in an aluminum cylinder series, that anything to cause overheating most certainly will lead to their ruin.
Regarding heat treating, has anyone ever tried chrome plating the piston ala KISS (
Krome plated
Iron piston running in a
Steel
Sleeve)?
