  • June 18, 2025, 11:11:12 AM
Author Topic: OS Max S .35 Break-in prop?  (Read 1192 times)
Offline Joe Ed Pederson
« on: February 26, 2019, 06:34:26 PM »
Anyone have the instruction sheet that came with the old OS Max S .35?  If so, what does it recommend as a break-in prop?
My guess would be a 9 x 5 or a 9 x 6.
Joe Ed Pederson
Cuba, MO
Re: OS Max S .35 Break-in prop?
« Reply #1 on: February 26, 2019, 07:53:22 PM »
Joe Ed Pederson
Cuba, MO
I ran them exclusively in the 70's and 80's.  Broke them in on a 9-4.  Never got a manual.  Don't let it break full lean for about 20 min. then mount it on something and point the nose up and down till it does a smooth 4-2-4.  If you can put an hour on it without overheating you will have a great stunt engine.  Don't forget the caster.   Use a 10 x 6W or EW(if you can find one) to fly it.
Others may have their own way but this one works.
« Reply #2 on: February 26, 2019, 08:19:01 PM »
Thanks, Ken.
I appreciate the guidance.
I run my other two Max S .35s on Sig Champion 10% Nitro and 25% caster.   I have a quart of Brodak 10% Nitro and 29% castor. Would you recommend running the quart of 29% castor through for the initial break-in runs?
Everyone says the weakness of the S .35 is the connecting rod.  It sounds like you used them enough to have a good idea how long the connecting rod lasts.  If you don't add oil journals to connecting rod, about how long do they last?
Thanks again,
Joe Ed
« Reply #3 on: February 26, 2019, 11:22:14 PM »
Thanks, Ken.
Thanks again,
Joe Ed
If the Caster is real caster that is about right.  We ran 30-35% with the nitro depending on the temperature.  More in the summer.  I have only had one con rod wear out.  "Big Art" set up mine and there was a nylon insert in the crankshaft pin that kept it in place.  I attribute that to the long life.  I have put over 1000 flights on the one I still have and it is starting to show signs of old age.  I think I ran it on some stuff with fake caster.
Good luck - Ken
Offline GERALD WIMMER
    • Auckland Free Flight Club
« Reply #4 on: February 27, 2019, 03:45:32 AM »
Hi
We stuffed a 35 recently. No real indication anything was amiss, when the grey goop came out the exhaust and all the innards were shot in a flight (the rod looked terrible!). We had been running 25% Benol Caster and not that many hours running but hard work on a heavy profile stunt trainer for our sons.
Regards Gerald
