  • July 16, 2025, 04:22:51 PM
Author Topic: Os Max La 46 5% vs 10 % fuel  (Read 1890 times)
Offline kevin king
« on: January 24, 2022, 11:28:25 AM »
Is there a noticable difference in quality of engine run, aside from taking up less fuel in the tank, less harsh on the finish, less cost and a small loss of power?
Re: Os Max La 46 5% vs 10 % fuel
« Reply #1 on: January 24, 2022, 01:30:49 PM »
   I haven't run a lot of 5% fuel in my LA.46s but it's pretty much like you suspect. Your run time will be longer, needle may be a bit more finicky, less toxic ona dope finish and just a bit down on power, but depending on the model you might not notice.
Online Peter in Fairfax, VA
« Reply #2 on: January 24, 2022, 01:48:00 PM »
Myself, I prefer the 5% for the LA 46, but will run 10% if I have no 5% available.
Offline Brad LaPointe
« Reply #3 on: January 24, 2022, 01:54:13 PM »
Kevin ,
Under 25 c - 5% works well . When it gets hotter than that the 10% helps .
Brad
Offline kevin king
« Reply #4 on: January 24, 2022, 03:29:33 PM »
Thank you gentlemen.
Offline Dan Berry
« Reply #5 on: January 24, 2022, 03:44:56 PM »
After coaxing from a few guys I went to 10% as the base fuel.
Offline Neil Rogers
« Reply #6 on: January 24, 2022, 10:14:54 PM »
Kevin,
I've always used 5% in my LA 46.  APC 11x5 will give a nice stunt run and do the pattern easily on 4 oz. of fuel.
Offline Jim Svitko
« Reply #7 on: January 25, 2022, 10:47:07 AM »
Most of the time, I rarely use more than 5% in any engine.   In the summer, I might have to use 10% depending on how heavy the plane is and what engine I have on it.  It might be necessary to change props as well.
At this time of year, with the cool days and low humidity, I can cut the nitro to 2% and still have enough power.
Offline Phil Spillman
« Reply #8 on: February 04, 2022, 03:47:47 PM »
When I bought my first OS LA .46 in 1998 I used a formula which my then flying partner preferred and that was: 7.5 22 &3! The 7.5 was Nitro @.98%pure, 22% Castor Oil and 3% synthetic! Lately I have changed from 10/ 11/11 to 7/11/11 with not discernable changes! If the weather gets really gummy here in the south I'll revert to 10/11/11 to make up for what our humidity and heat take out! It's not too unusual to have heat in the range of 95 to 100 degrees F with humidity of 95 to 98% to go along with it! Obviously these days aren't my favorites for work or play!
Phil Spillman
Phil Spillman
