  • June 17, 2025, 06:03:32 AM
Author Topic: OS Max FP35 vs S35  (Read 7727 times)
Offline Dick Pacini
OS Max FP35 vs S35
« on: November 19, 2010, 03:26:05 PM »
Can someone explain the difference?
AMA 62221
Offline John Miller
Re: OS Max FP35 vs S35
« Reply #1 on: November 19, 2010, 03:29:41 PM »
The fp is a schnuerly, the S is a cross flow. Different runs, and available power.
« Reply #2 on: November 19, 2010, 03:46:47 PM »
    The 35fp has about 3x the power and can pull small ST46 airplanes with good authority. The 35s runs nicely if you get the venturi small enough, and has the power of a Fox or slightly better.
Offline Dick Pacini
« Reply #3 on: November 19, 2010, 06:21:53 PM »
I have only had experience with the 35S from the early '70s.  I still have 2, one is stuck and the other is gummy but free.  I saw a 35FP on ebarf and was considering throwing in a bid.  Do you know what they sold for new and how long ago they were made?
AMA 62221
Offline Dick Pacini
« Reply #4 on: November 21, 2010, 09:49:46 PM »
Well, I scored a NIB OS Max FP35 on ebarf a couple of hours ago.  Time will tell if I made a good investment. :-\
AMA 62221
Dave Adamisin
« Reply #5 on: November 22, 2010, 06:00:05 PM »
Hi Dick. Is it a steel piston or abn? We ran several 35's back when they first came out. There wasn't a pressing need at the time for a smaller alternative to the 40 so we just used them up or sold them off. We modded them the same way we did the 40 as in: filled boost transfer and wedge head. The power was really good and we were able to use venturi's as large a .30 with ST needles. With the large vents the 35 would swing an 11x6 Super M. Normal vent size was .281.
Offline Dick Pacini
« Reply #6 on: November 22, 2010, 08:22:30 PM »
I don't know the specs on the piston and liner yet.  I hope to have the engine in a few days.  I probably spent too much, but that ebay bidding process can make a sane man do crazy things.
AMA 62221
Dave Adamisin
« Reply #7 on: November 22, 2010, 09:46:28 PM »
Always fun to get a new toy...... I still have a prepped and run in "new" fp40 steel piston from the day... I might build something for it or just keep it in the box with the Aero 35.
Offline Kim Mortimore
« Reply #8 on: November 22, 2010, 10:07:51 PM »
Hi Dave,
Some questions, since your clan has lotsa expertise with these engines, if you don't mind answering:
1.  Is it true that the ABN 35FPs all have a smoothly curved bypass where the OS MAX FP is stamped, and that steel pistons all have a raised "bump" (there's probably a better engineering term, but senility is setting in) to the left of the OS MAX FP?
2.  Did your mods allow a breaking run?  The 6" prop usually indicates this.
3.  If Dick wants to run his 35FP stock, would you recommend that he run a 4" pitch prop in a more or less constant 2-stroke?  As we all know, back in the day, folks experienced no end of grief trying to get the FPs to run like Foxes and "cure" the tendency to "run away", which was really just the engine seeking the RPM range it was designed for. And thus Dick could save himself from repeating history?
4.  My experience with stock 35FPs is they are powerhouses well suited to stunt if run with the lower pitch prop.  Would you agree?
Thanks.
Kim Mortimore
Santa Clara, CA
Offline Dennis Moritz
« Reply #9 on: November 23, 2010, 04:19:54 AM »
I have been running FP40s and FP35s for years. Both on sport planes and competitive stunt planes. So have most of our club members. None of these engines have been modified beyond adding head gaskets. We have found these engines to be powerful and effective in stunt.
Dave Adamisin
« Reply #10 on: November 23, 2010, 08:58:39 AM »
Hi Dave,
They both have full length transfers
Yes - see below
I believe that people have had success doing this
I'm not a fan of low pitch props. Just a personal thing. The first 4" pitch prop that I've flown that I like is the carbon prop I got from Bobby Mac. It's a 13.25x4.25 with an under-camber. Very nice prop.
Thanks.
Hi Kim. Yes the mods were made to make the engine 4-2. It was early in the fp's lifetime and 4-2 was what we did. The planes we were flying were large and needed a larger prop. I don't believe in a lot of head clearance when there is a squish band. I generally set the clearance to 0.007" - 0.012". If the compression ratio gets too high I either add exhaust timing (which lowers the "trapped" compression ratio) or open the chamber bowl. Large squish clearances isolate a large portion of the charge in a area that doesn't burn. On a 35 to 40 size engine with a squish area of 35% of the bore a 0.020" clearance is just less than 10% of the total charge in the squish volume. You take the time to trap the charge, you might as well burn it. Blocking off the boost lowers the angle/area of the intake ports to make them trap better at lower speeds necessitated by the large prop. I'm not saying there isn't another way, because there are, this is what we  did.
« Last Edit: November 23, 2010, 11:13:53 AM by Dave Adamisin »
« Reply #11 on: November 23, 2010, 01:29:35 PM »
Hi Kim
Adding a bit to what Dave said, one BIG reason people had so much "runaway" problem was that OS use to use a .157 diameter spray bar in this sized engine, When they made the 35FP they didn't make another spraybar , they used the tiny 20 spraybar,(still do even in the LA 46) it is .127 or .129 depends on when you bought them,
They DID keep the large venturie around 281 or 287 and this was way too large for a typical setup that people wanted to run...it is equivalent of about a 315 or so Venturie if you used the OLDER .157 size OS spraybar.
This along with the added power and people still wanting to use 6 pitch props was a recipe for lots of speed when the motor broke. And it would break very hard with the large venturie area. a .250 would be much closer, or just use a ST or PA NVAs they are the same .157 that OS used earlier
« Reply #12 on: November 23, 2010, 06:59:22 PM »
   Bingo on that one!  The stock venturi was close to workable *but not if you wanted to run it at 8500 rpm*. Mine worked pretty well stock here at sea level with a Tai-Pan 11-4 most of the time.
  I would also note that the 35 was a lot closer to working, stock, than the 40FP.
   Trying to run almost any of these engines with 6" of pitch is an exercise in frustration, which is why everybody thinks they need to be reworked.
Dave Adamisin
« Reply #13 on: November 23, 2010, 09:08:32 PM »
Certainly, but after they were reworked they ran great on 6" pitch props in large heavy planes.... Which is what we wanted at the time....
« Reply #14 on: November 24, 2010, 04:20:21 PM »
    But you give up so much performance that way you lose a lot of the advantage. Even bogged down that way, and stock, it was still close to an ST46 in performance on smallish 46 airplanes. 11.5 or 12-4, and the performance goes through the roof. The difference in shaft HP between 9000 and maybe 11,500 (in-air rpm with similar diameter) is tremendous.
Dave Adamisin
« Reply #15 on: November 24, 2010, 06:37:37 PM »
Shaft power doesn't equate to pull. If the prop isn't pulling the power isn't being delivered. If the air speed is the same the "aero-load"  being delivered seems to be the same. If air speed is the same, the power is the same. The 4 pitch is doing less work per rev than the 6 - about 33% less- so the power efficiency would be lower regardless of the shaft power. The 11x6 engines were spinning 10,000 in the air and making better, I believe, bmep at that speed than the stockers were. To be honest you mentioned an 11x4 not 5 in your last post and my reply is based on that. We also flew them with 12x5 Brian Eather 3 blade carbon props. The stockers wouldn't 4-2 and we wanted a 4-2 so we modded them to 4-2. I would be willing to bet that your never got more out of a stocker with an 11x5 than we got out of the modded motor with the 12x5 Eather. The engine my nephew won senior with in his 82oz fiberglass stunter was running a .301" vent with an st valve with the BE prop. He used 4.5oz of fuel with one of my dads mufflers. It was the angled piece. We did that because the stockers due to the twisted exhaust differentially heated the case enough to cause a bind when they were running so we cut the stack at an angle to allow the gasses to flow out without impinging directly on the case. You can prove it yourself. Put an fp in the running stand and heat it up. If you check it as soon as it quits you will notice a small bind that goes away as the engine cools. We measured a 500 rpm increase with a 9x5 at peak cut stack vs stock. Less heat also meant less tendency to run away. I understand the relationship between rpm and power. I understand the relationship between bmep and power too. The .301  vent would allow for better vol eff than the .250 if it was trapped, so I'm not going to even give the stocker a shaft power advantage at the speeds we're talking about. This is a good topic.. By the way, our liners were unmodified and we got more power out of the steel piston engines...
Offline Dick Pacini
« Reply #16 on: November 24, 2010, 10:50:42 PM »
I hope you guys keep this up.  I know nothing about the FP35 I just bought. b1
AMA 62221
« Reply #17 on: November 25, 2010, 01:08:21 AM »
   Of course - although I gave up trying to explain that to various personages on SSW a long time ago.  The key is speed stability, not the actual speed. If you are delivering a large amount of shaft HP, but not going any faster in level flight, you are running at a very inefficient operating point. This is ideal for stunt, because as it slows down, the efficiency rapidly climbs, just when you need it  - and not requiring any other action of the engine. This is why 4" was such an incredible breakthrough.
    Running at the low revs for 6" of pitch, with the necessary changes to keep it there, is just death for the power available. And also why, with a few notable exceptions, nobody does it any more.
« Reply #18 on: November 25, 2010, 04:28:21 AM »
In our club we setup FP35s and 40s as follows:
FP needle, 101/2x41/2 apc, free flowing exhaust (usually a tongue muffler with a lot of holes), .283 venturi, one or two extra head gaskets, Enya #3 plug, or Thunderbolt RC, Powermaster 22%(50/50) 5%. Needle is set to run a medium 2 stroke in flight which will break to a hard 2 stroke in maneuvers. If it take about 4.5 ounces of fuel to do the pattern, you're in the ball park. Sufficient fuel needs to be run through the engine to keep it cool and controllable. Or so we theorize. If the break is too hard an extra head gasket or two, usually solves the issue. Please note that head gaskets vary. Stock OS gaskets are .015, aftermarket gaskets from Leonard Neuman, RSM (I believe) or Tower, if you can find them, run .010. 2 OS means 3 Tower. Buy the gaskets from Leonard, very reasonable cost. Many many times we have found that a balky runaway engine is caused by the usual gremlins: clogged filter, leaky tank (even a pinhole leak raises havoc with uniflo), airplane vibration, poor choice of fuel, worn plug or wrong plug, venturi seal or back plate leak, worn front bushing, in other words the setup works when the plumbing etc. is as it should be. Vibration problems plague profiles, of course, and can be a factor in full fues planes as well. A solid front end is essential, it seems to me, to establishing a reliable and useful tune.
Needle valve adjustment can be critical and sensitive. A click or two either way can mean the difference between usable, predictable power, and over lean jet speed. These engines need to be tuned for performance in flight. Ground setting may or may not be an accurate predictor of in flight engine run. This is especially true on profiles, since vibe issues are common. If engine runs too rich when flying I add a click or two next flight. If too lean, the opposite. It usually works out better, when tuning a new engine/plane combo, to start with an overly rich setting gradually leaning a click or two each flight. The sweet spot may be narrow. Solid front end planes tends to provide more latitude in adjusting for the sweet spot.
Tower 40s are handled similarly and perform similarly in my experience.  The Tower 40 is a near FP clone. The cylinder is chrome plated vs. nickel plated. The head appears to have deeper fining and the combustion chamber looks a bit more shallow (or visa/versa, I forget.) When tuned correctly we've found FPs to be powerful effective stunt power. Members have used them successfully in Advanced Pampa and Expert profile at local contests and Brodak. So far FPs and Towers with re-timed sleeves, that we've observed, are down on power. I have seen a Byron Barker modded engine that ran well. It's my understanding that BB does not re-time the engines. Hemi heads reduce the squish band and lower compression. I've seen them work. It's been our experience that adding head gaskets produces a similar effect while allowing for flexible adjustment.
« Last Edit: November 29, 2010, 01:20:44 PM by Dennis Moritz »
Dave Adamisin
« Reply #19 on: November 25, 2010, 07:26:59 AM »
temporal arrangement
noun
arrangement of events in time
Ahhh the root of the thread. and the difference between an fp and an S H^^
« Reply #20 on: November 26, 2010, 10:07:09 AM »
35S run a traditional 2x4 break out of the box. Mild mannered. Run great when in good repair. Soft break. Predictable. East to setup. Considerably down on power IMHO compared to hyper FPs. 35s (es) have a non-bushed rod and, I think, no oil slit in the lower end. Will wear out a rod after a while. Leonard sells fully bushed replacement rods for $16. All 35s are cast iron piston in a steel liner. Over lean runs can cause damage and/or premature wear.
« Reply #21 on: November 26, 2010, 02:33:54 PM »
"Leonard sells fully bushed replacement rods for $16. All 35s are cast iron piston in a steel liner. Over lean runs can cause damage and/or premature wear.  "
Correction  he does not sale fully bushed rods for 16.00
I have the same rods for sale, they are made of much harder Alum. but they are not bushed
Also the sleeves are soft in the motors and the metal wrist pins pads cut grooves into the sides of the sleeve
Dave Adamisin
« Reply #22 on: November 26, 2010, 03:47:59 PM »
Yep you should replace the pin pads with teflon... Man the old motors were a lot of work.....
Offline Mike Greb
« Reply #23 on: November 28, 2010, 05:01:29 AM »
Dave Gerki (sp) told me that he replaced the rod on his OS35s every 70 flights.  The stock rod also has a tendency to gall on the crankpin if not enough oil is used. The os35s is a nice running motor, but if you are planning to run them a lot, say hundreds of flights, you really need to pick up a couple of extra to make sure you have enough spare parts.  Another weak point in the 35s is the wrist pin hole in the piston, they tend to wear out.
Offline Terrence Durrill
« Reply #24 on: November 29, 2010, 11:43:54 AM »
Ok, I understand Randy Smith is the source for the better connecting rods for the OS Max .35S.  Does any one know a source for wrist pin teflon pads for the Max .35S.........TDurrill  ???    H^^
« Reply #25 on: November 29, 2010, 09:36:11 PM »
I sell the wrist pins with the pads installed. rods and NVAs for the old 30  35 S,  I may have some other parts soon
you can reach me here or  at www.aeroproduct.net
678/407/9376
