  • June 18, 2025, 01:51:13 PM
Author Topic: LA 46 Venturi Set-Up  (Read 1037 times)
Offline Peter in Fairfax, VA
« on: May 05, 2019, 09:23:51 AM »
So I have this full bodied stunter that fits an O.S. LA 46.  Just bought a used engine off eBay, which should arrive late this week.  It's an R/C.  Plan to sell the carb / remote NVA on eBay, because it would just be clutter for a CL person.  Now I need an NVA / Venturi.
Though I looked at Lee Machine, I liked the offering on eBay from shtterman which includes not only an NVA, but also a 4mm bit to drill the case.  I plan to stuff a rag in the intake, tape closed the exhaust, invert the engine and drill with a vacuum cleaner running below, then flush the engine.
The supplied NVA is from Enya.  Are they any good?  If it doesn't work out, I'll see if I have a SuperTigre, Harry Higley or something better.
https://www.ebay.com/itm/OS-FP-LA-35-46-C-L-VENTURI-AND-ENYA-TYPE-NVA-NIP-DELRIN-6-5-MM/223473017798?hash=item340807a3c6:g:H7gAAOSwt5hYbuBP
Online Carl Cisneros
Re: LA 46 Venturi Set-Up
« Reply #1 on: May 05, 2019, 11:57:40 AM »
Petter
read the message i just sent you
Carl
Carl R Cisneros, Dist IV
Control Line RB
« Reply #2 on: May 05, 2019, 12:14:22 PM »
I have also used the NVA that Bobby sells and they work a treat for me.
used on:  LA46, 35S, H60 OS, Enya motors, K&B, HB and HP motors.
Carl
Control Line RB
« Reply #3 on: May 05, 2019, 03:09:07 PM »
   shtterman also sells a needle valve assembly that does not need drilling on an OS engine. I think he had Enya make some to OS specs for him. A better option of you do not want to drill your engine.
Offline Allen Eshleman
« Reply #4 on: May 07, 2019, 06:33:02 PM »
I drilled one on a drill press with a vise holding it.  That was my first time.  Worked like a charm for me.  That was on an FP-25.
