Hi Bill; If it were me I would just block off half of the venture with a stick and run it on the rich side with a fairly good prop load that will keep the rpm down. On the old OS four strokes they said to run them wide open and use the needle to keep them at about 4,000 rpm. That also works well. Do check the valve clearance before running, and after running a while.
