Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
June 19, 2025, 08:22:34 PM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
OS 46 LA limits
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: OS 46 LA limits (Read 1939 times)
Casey
Trade Count:
0
Lieutenant
OS 46 LA limits
on:
November 13, 2014, 10:37:55 AM »
Is a full fuselage 60 inch wing span 705 square inch 56 oz plane too much for an OS 46 LA to haul around for a full schedule? If it not, what should be the maximum line length?
Logged
Steve Helmick
24 supporter
Trade Count:
0
Admiral
Re: OS 46 LA limits
Reply #1 on:
November 13, 2014, 10:35:50 PM »
More to it than area and weight...airfoil thickness and drag in general. Do you want to use CF props and run 20% nitro? Etc.
Logged
In 1944 18-20 year old's stormed beaches, and parachuted behind enemy lines to almost certain death. In 2015 18-20 year old's need safe zones so people don't hurt their feelings.
Howard Rush
25 supporter
Trade Count:
0
Admiral
Re: OS 46 LA limits
Reply #2 on:
November 14, 2014, 11:03:34 AM »
Quote from: Steve Helmick on November 13, 2014, 10:35:50 PM
More to it than area and weight...airfoil thickness...
What does airfoil thickness do? Show us some data.
Logged
Tim Wescott
25 supporter
Trade Count:
0
Admiral
Re: OS 46 LA limits
Reply #3 on:
November 14, 2014, 11:09:57 AM »
About two years ago I asked "what's the best plane size for an LA 46". The consensus seemed to top out at around 630 to 650 squares.
http://stunthanger.com/smf/index.php/topic,31124.0.html
If you built really light, you may be able to struggle through the pattern in light winds with a bigger plane -- but why?
Logged
Dave_Trible
24 supporter
Trade Count:
0
Admiral
Re: OS 46 LA limits
Reply #4 on:
November 14, 2014, 12:05:19 PM »
About airfoil thickness, never had much luck doing eights with a rat racer. I'd think your .46 would be hard pressed to pull that much airplane effectively. That motor is nice but more like a .40 in power output.
Logged
Jim Thomerson
Trade Count:
0
Admiral
Re: OS 46 LA limits
Reply #5 on:
November 14, 2014, 02:39:01 PM »
That was my Humongous except 52 oz. K&B 4011 flew it just fine. I suspect a K&B 4011 is a more gonzo engine than a LA 46, but have no comparative data.
Logged
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
OS 46 LA limits
