  • July 04, 2025, 01:54:15 AM
Author Topic: os 32 with tuned pipe  (Read 1687 times)
Offline Richard Lotspeich
« on: May 27, 2018, 06:25:07 PM »
Hi Randy
i have an OS 32 that I used to run with a tuned pipe many years ago. I don't have the same pipe setup anymore, I wanted to try and pipe it again, but don't know where to start as far as length of pipe. Can you give me a starting point?
Dick Lotseich
Re: os 32 with tuned pipe
« Reply #1 on: May 27, 2018, 08:14:40 PM »
Hi Randy
Dick Lotseich
What prop are you going to  use? most use a  11 x 4  or  10.5 x 4  ,  If your  using that setup you would  start at about 17.5 nches from plug to  first baffle. Then you can give me  RPM info and  how it  acts  n the maneuvers
« Reply #3 on: May 27, 2018, 08:36:14 PM »
Thanks Randy
That is what I wanted to know. i will try it.
Dick
Offline Bootlegger
« Reply #4 on: May 30, 2018, 08:30:24 AM »
Randy, Would an 11x4 prop be good on an O S 32 without a pipe also, or does it need the pipe?
8th Air Force Veteran
Gil Causey
AMA# 6964
« Reply #5 on: May 30, 2018, 09:37:40 AM »
Yes  the  11 x 4  is  good for  many stuntships running that motor
Offline Bootlegger
« Reply #6 on: May 30, 2018, 06:19:04 PM »
  Randy, thanks, Gil..
Gil Causey
AMA# 6964
