  • July 06, 2025, 09:30:11 PM
Author Topic: os 25 la r/c  (Read 780 times)
Offline rich gorrill
os 25 la r/c
« on: August 12, 2013, 06:44:16 PM »
Is the 25 la r/c engine the same as the control line model with the exception of the Carb. I know you can buy the little gizmo that replaces the carb. I just wondered if the internals were the same. Their are a lot of r/c models for sale on the
Bay I hate to buy one and find it won't perform properly after the carb is replaced.
Thanks, Rich
Re: os 25 la r/c
« Reply #1 on: August 12, 2013, 07:59:07 PM »
Word on the street is that they come into the USA as R/C versions and get the venturi installed here. I'm not real sure I believe that, but the parts lists don't show any different part number, other than the throttle and venturi bits. You should be able to prove this to yourself here:  http://www.osengines.com/manuals/   H^^ Steve
Offline Duke.Johnson
Re: os 25 la r/c
« Reply #2 on: August 12, 2013, 08:19:20 PM »
Everyone has told me they are the same and I've been buying RC engines and putting in the venture.  They work great.
Offline Jeff Traxler
  • T-Bone
Re: os 25 la r/c
« Reply #3 on: August 12, 2013, 11:03:31 PM »
Rich,I have a couple of them and all I did was to swap out the venturi and install a conventional nva.One of them had the remote needle broke off and I cut the other one off.It hauls my Brodak Buster around with authority.Trax
Re: os 25 la r/c
« Reply #4 on: August 13, 2013, 04:27:33 AM »
Mystery solved,thanks guys.  This will open up my options when it comes to bidding on engines on the Bay.
Rich
