  • August 05, 2025, 04:03:24 AM
Author Topic: OS Max 35 S with mounting holes aftermade....compatibility????  (Read 1677 times)
Offline Manuel Cortes
« on: January 20, 2017, 02:03:54 PM »
Hi All.
Iīve been able (My friend Quique did it) to modify an OS 35s in order to attach a standard muffler screwed in typical manner. The old (1995) plain bearing Stalker 35, 40, 42 and 46 silencers are a perfect fit.
I am planning to use a tongue in a future, there is other OS engine with the same space between screws?
Thanks very much from Spain.
Manuel.
Re: OS Max 35 S with mounting holes aftermade....compatibility????
« Reply #1 on: January 20, 2017, 02:39:38 PM »
If it fits those Stalker silencers, then probably anything that fits those engines will fit yours.
I'm curious how it was done -- could you post a picture?
« Reply #2 on: January 20, 2017, 10:22:35 PM »
you just drill  thru the  holes  in the  inside  edges of the  exhaust  and out the back side of the  case, you can then use  tube or tongue mufflers  putting them on from the back of the motor
It is 1.25 span  and is  the same  as the  NEW OS LA 25   and the  ST 34
some other engines  take the same size
some OS 35 S  have the  holes inside the exhaust drilled and tapped, other have  just a block of metal there that you can drill, same for the  OS 30 S
« Reply #3 on: January 20, 2017, 10:46:22 PM »
Hi all.
Thanks very much for the quick responses!!!!
I am unable to send potos as the engine is in a friendīs shop, but Randy has explained perfectly the process.
Regards from Spain.
Manuel.
Re:
« Reply #4 on: January 20, 2017, 11:10:11 PM »
By the way, we have checked that tighting excessively the silencer distorts slightly the case, as with the strap.
Enviado desde mi Y635-L01 mediante Tapatalk
