  • July 17, 2025, 07:40:24 AM
Author Topic: OS .20FP venturi in OS .46LA  (Read 1338 times)
« on: July 30, 2015, 04:45:23 PM »
Need a guideline of fuel consumption using the .20FP venturi in the .46LA.  I know it does cut the power a bit, but that will not be a problem.  What I would like to know is a guideline as to how much fuel is being used with the small venturi.  List what amount you use and what % nitro, etc..  Any other material pertaining to the set up will be appreciated!
Thanks!'
Re: OS .20FP venturi in OS .46LA
« Reply #1 on: July 30, 2015, 08:50:39 PM »
contact Pat Johnston, he used or uses a small venturi in his LA 46 setups,, I think its .272 or smaller maybe
I seem to recall him using like 3 ounces for the pattern.
I am not positive, but I think he was spinning the 12.25 x 3.75 apc at around 9800
Online Gerald Arana
« Reply #2 on: July 31, 2015, 10:08:24 AM »
Bill,
Part # 22312000 at "Tower" is 6MM and is for the LA 25. Works great in the 46. The LA 46 comes with a 7MM venture.
I also use the #762 muffler with the small exhaust and my engines use about 3 OZ's for the pattern (10/22) and an 11 X 4 wood prop.
Quiet and smooth!
Good luck, Jerry
« Reply #3 on: July 31, 2015, 03:29:08 PM »
Thanks, Mark and Jerry!
