  • June 21, 2025, 06:49:17 AM
Author Topic: Testers/McCoy 35  (Read 1168 times)
Offline Shawn Kuntz
  • Ringmasters Forever!
Testers/McCoy 35
« on: March 07, 2007, 08:08:56 PM »
I have a Testers/McCoy 35 blackhead and could use a new head gasket.  The engine runs and pulls my old heavy Ringmaster around but I feel it may be short on power.  I think the head gasket leaks because fuel bubbles around the head and cylinder joint when the engine is hot.  It runs for now and I will keep on using it until I can find a replacement gasket.  The big question is..Does anyone know where I can find a new gasket for this old motor?  This was my first big motor as a kid and I bought it with my Grit paper route money.  Mail ordered it from Americas Hobby Center, New York City back in '79 or '80.  Thanks!
Shawn Kuntz
Bismarck, North Dakota USA
Offline Russell Shaffer
Re: Testers/McCoy 35
« Reply #1 on: March 07, 2007, 09:11:38 PM »
Try this.  They have lots of parts for old engines.   https://shop.mecoa.com/shopdisplayproducts.asp?id=102
Russell Shaffer
Klamath Falls, Oregon
Offline Shawn Kuntz
« Reply #2 on: March 07, 2007, 10:23:44 PM »
I ordered the parts I need.  Thanks!
Shawn Kuntz
« Reply #3 on: March 08, 2007, 10:30:27 AM »
you can cut an adequate gasket from a pop can.  Cut it up, flatten it out, and scribe the circles using a drafting compass with a sharp point in it.  Go over the marks with an exacto #11 until the aluminum cuts through.
Offline Shawn Kuntz
« Reply #4 on: March 08, 2007, 10:58:01 AM »
I never thought of that.  What a simple and practical solution! I will remember that for next time.  Thanks!
Shawn Kuntz
Offline Bootlegger
« Reply #5 on: March 09, 2007, 07:14:51 AM »
  I have found that lots of time other 35 40 engine gaskets also fit.  I have used OS gaskets in a variety of engines and they worked well...  Food for thought...
8th Air Force Veteran
Gil Causey
AMA# 6964
« Reply #6 on: March 09, 2007, 07:28:16 AM »
Fox 35 head shims fit the Red Head 35s according to Sir Thomas of Luper.
They *should* fit the McCoy Series 21, too, then.  I'll check........ IF I can remember to! ;D
