Engine basics => Engine set up tips => Topic started by: Shawn Kuntz on March 07, 2007, 08:08:56 PM
Title: Testers/McCoy 35
Post by: Shawn Kuntz on March 07, 2007, 08:08:56 PM
I have a Testers/McCoy 35 blackhead and could use a new head gasket.  The engine runs and pulls my old heavy Ringmaster around but I feel it may be short on power.  I think the head gasket leaks because fuel bubbles around the head and cylinder joint when the engine is hot.  It runs for now and I will keep on using it until I can find a replacement gasket.  The big question is..Does anyone know where I can find a new gasket for this old motor?  This was my first big motor as a kid and I bought it with my Grit paper route money.  Mail ordered it from Americas Hobby Center, New York City back in '79 or '80.  Thanks!
Title: Re: Testers/McCoy 35
Post by: Russell Shaffer on March 07, 2007, 09:11:38 PM
Try this.  They have lots of parts for old engines.   https://shop.mecoa.com/shopdisplayproducts.asp?id=102
Post by: Shawn Kuntz on March 07, 2007, 10:23:44 PM
I ordered the parts I need.  Thanks!
Post by: phil c on March 08, 2007, 10:30:27 AM
you can cut an adequate gasket from a pop can.  Cut it up, flatten it out, and scribe the circles using a drafting compass with a sharp point in it.  Go over the marks with an exacto #11 until the aluminum cuts through.
Post by: Shawn Kuntz on March 08, 2007, 10:58:01 AM
I never thought of that.  What a simple and practical solution! I will remember that for next time.  Thanks!
Post by: Bootlegger on March 09, 2007, 07:14:51 AM
  I have found that lots of time other 35 40 engine gaskets also fit.  I have used OS gaskets in a variety of engines and they worked well...  Food for thought...
Post by: Bill Little on March 09, 2007, 07:28:16 AM
Fox 35 head shims fit the Red Head 35s according to Sir Thomas of Luper.
They *should* fit the McCoy Series 21, too, then.  I'll check........ IF I can remember to! ;D
