  • July 19, 2025, 01:30:50 AM
Author Topic: O S 30 Stunt  (Read 1378 times)
Offline Bootlegger
O S 30 Stunt
« on: September 23, 2018, 11:27:15 AM »
 What size venture do I use on this engine, and what needle assembly will work best ?   Thanks
8th Air Force Veteran
Gil Causey
AMA# 6964
Re: O S 30 Stunt
« Reply #1 on: September 23, 2018, 03:12:48 PM »
   Anything off an OS Max-S .35 will fit. They are a little shorter that the FP-LA stuff, and standard OS NVAs will work.  Jim Lee or Randy Smith should be able to fix you up with what you need.
Offline Dane Martin
  • heli pilot BHOR
Re: O S 30 Stunt
« Reply #2 on: September 23, 2018, 03:28:38 PM »
We were flying Charles Fata's P40 with an OS30S today. It's a dang nice running engine.
Offline Bootlegger
Re: O S 30 Stunt
« Reply #3 on: September 24, 2018, 03:14:10 PM »
 Sacre Bleu, I found a venture in my O S 30 "goodies" so now the next project is how to drill the case and mount a tongue muffler?  Suggestions ??
 Oh, Sacre Bleu is French for something like WOW!!!
Gil Causey
AMA# 6964
Re: O S 30 Stunt
« Reply #4 on: September 24, 2018, 04:03:31 PM »
'Legger,
My reply apparently got lost in the ether last night....
Shorter version: I have two. Both have P/L that are pretty worn. They both use a .257 nylon venturi and .135 OS needle. Both run steady as a clock on 10/28 castor fuel. Classic runs.
Good luck with yours,
Divot McSlow
Re: O S 30 Stunt
« Reply #5 on: September 24, 2018, 06:14:44 PM »
Apparently , its more like ' Fudge ' or ' Bother ' .
