  • June 25, 2025, 05:56:56 PM
Author Topic: NVA Direction  (Read 774 times)
Dwayne
NVA Direction
« on: August 11, 2011, 12:58:51 PM »
Does it matter which way you mount a NVA? I'm using a clunk tank with a solid uniflow tube with an inverted engine this puts the pickup on the inside, is this ok?
Thank you
Offline Bootlegger
Re: NVA Direction
« Reply #1 on: August 11, 2011, 04:25:17 PM »
 :!   I alway's try to mount mine where I can set the needle without having to fight the hot exhaust/muffler.
  They have been run behind the engine at times to accompolish this.
    My vote is no, it doesen't matter which sice the fuel comes in on.
   Good luck, and let us know how it works... o2oP
8th Air Force Veteran
Gil Causey
AMA# 6964
Dwayne
Re: NVA Direction
« Reply #2 on: August 11, 2011, 05:56:32 PM »
Thanks Gill  y1
