  • July 08, 2025, 11:35:33 AM
Author Topic: FOX 35 plasma PIston\sleeve sets  (Read 996 times)
« on: January 09, 2008, 11:45:10 AM »
The new plasma  piston\sleeve  sets  FOX sells for its  35 have a small problem. The skirt of the piston is .037 inch longer than the typical FOX 35 piston. These  will interfere on some but not all model FOX 35s. FOX has been made aware of this problem by Marvin  and has corrected it. So if you have one of these parts be careful and check it when you install the parts in your motor. Or send it back to FOX for modifying
Offline Gordon Tarbell
Re: FOX 35 plasma PIston\sleeve sets
« Reply #1 on: January 09, 2008, 09:05:20 PM »
Does this P/L set (Plasma) give a smaller disp. ? If so How much disp. loss?
Gordon Tarbell AMA 15019
Offline Jim Oliver
« Reply #2 on: January 09, 2008, 09:22:35 PM »
Short answer--No/same displacement.
Better answer---see Marvin Denny's comments in Product Review section.
Cheers,
Jim
Jim Oliver
AMA 18475
« Reply #3 on: January 09, 2008, 11:09:59 PM »
Hi Gordon
The FOX plasma piston/sleeve set is a drop in fit for the FOX 35 and it uses the same head as the standard FOX, it is the same bore uses the same  pin, clips, rod  etc.  The first plasma  piston/sleeve sets I got in from OZ that were aftermarket  de bored the  FOX 35 to a 32, and was  sent  with  a new smaller head to fit the new smaller  bore. That is not the case with the  FOX factory product.
