Engine basics => Engine set up tips => Topic started by: RandySmith on January 09, 2008, 11:45:10 AM
The new plasma piston\sleeve sets FOX sells for its 35 have a small problem. The skirt of the piston is .037 inch longer than the typical FOX 35 piston. These will interfere on some but not all model FOX 35s. FOX has been made aware of this problem by Marvin and has corrected it. So if you have one of these parts be careful and check it when you install the parts in your motor. Or send it back to FOX for modifying
Regards
Does this P/L set (Plasma) give a smaller disp. ? If so How much disp. loss?
Short answer--No/same displacement.
Better answer---see Marvin Denny's comments in Product Review section.
Cheers,
Jim
Hi Gordon
The FOX plasma piston/sleeve set is a drop in fit for the FOX 35 and it uses the same head as the standard FOX, it is the same bore uses the same pin, clips, rod etc. The first plasma piston/sleeve sets I got in from OZ that were aftermarket de bored the FOX 35 to a 32, and was sent with a new smaller head to fit the new smaller bore. That is not the case with the FOX factory product.
Regards
