  • June 21, 2025, 12:05:15 PM
Author Topic: Newer Black Widow Modification.  (Read 1319 times)
Offline Tom Perry
« on: March 01, 2008, 04:15:41 PM »
Has anyone any information on modifying the newer Cox BW for stunt use?  Can the tank and or backplate be rigged to operate like the older one with the tank vent to allow for normal and upside down flight?  can the tank be modified to accommodate the vents as in the older one?  if so what do you use to hold and seal the vents?   ???
Tight lines,
Tom Perry
 Norfolk, Virginia
Re: Newer Black Widow Modification.
« Reply #1 on: March 01, 2008, 05:44:37 PM »
Ray (minnesota modeler) has posted pictures of a set up that uses notched fuel tubing that goes around the tank and the notch is at the bottom.
Offline Tom Perry
« Reply #2 on: March 02, 2008, 06:23:23 AM »
I've seen that but was wondering if there was a way to duplicate the older style.   AP^
Tight lines,
Tom Perry
 Norfolk, Virginia
« Reply #3 on: March 02, 2008, 06:59:40 AM »
Do I like did on a couple.  Drill holes to fit tubing, kind of a force fit.  Then J-B Weld inside as well as out.  DOC Holliday
Offline Tom Perry
« Reply #4 on: March 02, 2008, 07:33:51 AM »
This is what I was looking for.  What did you do about closing the vents on the back plate?  I will probably sub the metal backplate from a baby bee and will drill out the venturi.  I sent Ray Stone a couple of back plates some time ago. maybe he will chime in here?   :)
Tight lines,
Tom Perry
 Norfolk, Virginia
Online kenneth cook
« Reply #5 on: March 02, 2008, 05:17:31 PM »
            Tom , I tried using the older vented stunt tank with the metal baby bee back plate. I used very small fuel tubing with dowels jammed in the ends to cap off the baby bee fuel nipples. This didn't work too well for me. The tubing would always pop off for starters and I don't think it was completely air tight. I never got a full run from this. I think Jb Weld would do a better job of blocking those nipples. I saved a lot of the backplates from the plastic model engines similar to those on the production engines. I found using these with a small tank gave me a whole lot less trouble. Some of the needle valves on some of my backplates had some very fine threads which suited bladder usage. Ken
Offline Joey Mathison 9806
« Reply #6 on: March 02, 2008, 07:13:31 PM »
tom you may try to soft solider the baby bee holes
200 mph man ama#9806 joey mathison
Offline minnesotamodeler
  • Me and my Chief Engineer
    • Minnesotamodeler
« Reply #7 on: March 17, 2008, 07:09:06 AM »
Hi Tom, sorry I just now found this, I don't usually check all the forums.
If you just cap one of the vents after filling, it will work sort of like a uniflo, and won't lose any fuel inverted since it's drawing air through the single vent.  The notched fuel line looping around the bottom really didn't work too well, hard to keep it on the vents. Best is to use an external tank of your choosing.  You can drill a hole through the side of the integral tank and install a fuel line to the nipple, or buy a Cox production engine ($8?) and use its backplate.
--Ray
--Ray
AMA902472
Online Paul Smith
« Reply #8 on: March 17, 2008, 07:38:36 AM »
Another painless way to deal with it is to rotate the backplate so the NV and vents are inboard, and of course, make sure the pickup is still outboard.
You'll have to hold the plane kinda funny while you're starting it, but it will be perfect in the air.
