  • June 22, 2025, 05:52:52 PM
Author Topic: New to me Webra .40 Silverline  (Read 4160 times)
Offline Terry Caron
« on: June 19, 2014, 10:45:16 AM »
Useful for stunt?
How's it compare to .40 FP or other similar size engines?
Thanks.
Terry
NACA member, Huntsville, AL
AMA 249824
NRA Life Member
Offline Andrew Tinsley
Re: New to me Webra .40 Silverline
« Reply #1 on: June 19, 2014, 11:14:34 AM »
I don't have any experience with Webra engines, but they seem to be performance engines, I would be surprised if they were stunt friendly.
Andrew.
BMFA Number 64862
Offline Terry Caron
« Reply #2 on: June 19, 2014, 11:46:50 AM »
Hi Andrew -
There is a different schneurle scavenged Hi-perf Speed series made in Austria- this one is Dykes-ringed baffled, made in Germany.
Terry
« Last Edit: June 19, 2014, 12:40:03 PM by Terry Caron »
AMA 249824
NRA Life Member
« Reply #3 on: June 19, 2014, 04:17:26 PM »
I ran a Webra 61 Black Head baffled ringed engine in R/C pattern a few years, and it ran great with good peformance and wear characteristics. I do not know much about the 40 but I would think it would be worth a try unless someone in the know says differently. The 40 looked just like the 61. The 61 I had even had needle bearings on the rod big end. They got replaced for the most part by the Webra Speed Schneurle 61. R/C pattern engines were never on top for very long as someone always came out with something new and better.
« Reply #4 on: June 19, 2014, 06:48:42 PM »
AARGH! Possibly the best stunt engine of all time was the 40VF, and it was a "performance" engine, too.
« Reply #5 on: June 20, 2014, 02:26:16 PM »
Certainly true Brett but I don't see many stunt 40 VF  flying without a pipe. I bet a stand alone 40 VF without a pipe would not be very stunt friendly.
Andrew.
BMFA Number 64862
Offline Terry Caron
« Reply #6 on: June 20, 2014, 02:36:49 PM »
So, has no one experience with the Webra .40 (A.K.A. 6.5) Silverline in a stunter?
Terry
« Last Edit: June 20, 2014, 06:10:59 PM by Terry Caron »
AMA 249824
NRA Life Member
« Reply #7 on: June 21, 2014, 11:01:52 AM »
Terry
HI Terry
Yes I bought several of those years back, they are just OK for stunt, they did not measure up to the HP 40 and others, so I did not go any farther with them. You do need to make sure you have spare parts, so you can get one that is fit very well
Offline Terry Caron
« Reply #8 on: June 21, 2014, 11:13:42 AM »
HI Terry
Would you elaborate on shortcomings Randy?
I got this primarily because of a perception of Webra's reputation for quality, but your comment about spares implies not so much.
Terry
AMA 249824
NRA Life Member
« Reply #9 on: June 21, 2014, 01:41:57 PM »
Terry
They didn't produce a lot of power, and the ring fit was suspect, then the rings wore pretty fast, compression suffered. An  HP 40 would be a much better choice, as would many other engines TT36  AT 36 , ST46 , ST51, OS 46, OS 40H , Royal 40 Royal 45, FSR 40 FSR 45, Magnum Old Style 40 or 45, Older mag Gp44  ie...........
Offline Terry Caron
« Reply #10 on: June 21, 2014, 01:46:47 PM »
Well.
Live and learn.
Thanks.
Terry
AMA 249824
NRA Life Member
Offline Robertc
« Reply #11 on: July 08, 2014, 09:25:07 AM »
I had one for short period of time.  Just as Randy said, rings were out of round and power was no better than a FP 40.
Not really a bad engine, just so many others that are better.
« Reply #12 on: July 08, 2014, 03:46:39 PM »
You could contact Frank Bowman about piston rings. That alone could improve things a lot.  H^^ Steve
