  • June 22, 2025, 05:44:19 PM
Author Topic: Tube muffler rework  (Read 1486 times)
Offline tom brightbill
Tube muffler rework
« on: July 08, 2014, 09:48:06 AM »
I need to rotate the exit piece on a tube muffler. I believe that it is probably held on by JB Weld or a similar product.  I think that I saw a thread here once that mentioned heating the casting and thereby softening the epoxy, allowing it to be re positioned.  Does anyone else recall this thread? My searches have come up with everything except the answer.  Thanks.
AMA 34849
Online FLOYD CARTER
Re: Tube muffler rework
« Reply #1 on: July 08, 2014, 10:40:04 AM »
Yes.  JB Weld is tough stuff, but it can be softened/weakened with heat.  I've added metal "stingers" to the end of tube mufflers using JB Weld, and it holds fine.  It is less successful used close to the engine, where temps are much higher.  So, I suggest putting the muffler in a hot oven, and then twist it or pry it apart.
« Reply #2 on: July 08, 2014, 03:42:49 PM »
What tube muffler, Tom?   ??? Steve
Online Tim Wescott
« Reply #3 on: July 08, 2014, 04:06:44 PM »
Careful!  He might start listing all his projects!
« Reply #4 on: July 08, 2014, 10:48:11 PM »
Steve, it's for a Stalker 51.
AMA 34849
« Reply #5 on: July 09, 2014, 12:16:45 AM »
Alan Resinger is the BC connection for Stalkers, so I would suggest shooting him an email and asking what he can suggest.  H^^ Steve
