  • June 14, 2025, 10:02:51 AM
Author Topic: Super Tigre G .46 Rear Inlet?  (Read 1001 times)
Offline TigreST
  • TigreST
« on: April 11, 2020, 02:35:11 PM »
Question: Does anyone have any info on the 1970's era (I thnk?) Super Tigre G .46 r/c Rear Inlet motors?  I expect that they are some sort of hot setup for racing or performance flying use.  All google does is take me to ebay sales.  I was wonder if they compare to the famous stunt G-21 .46 at all, most likely not.   Thanks for any info.
« Last Edit: April 11, 2020, 07:24:55 PM by TigreST »
Tony Bagley
Ontario, Canada
Offline TigreST
  • TigreST
Re: Super Tigre G .46 Rear Inlet?
« Reply #1 on: April 11, 2020, 05:28:52 PM »
Not sure on the weight Motorman.  G21-.46 is plain bearing or ball?   The basic outline looks similar to me.  I don’t have this motor, just stumbled acros it and wondered.
Tony Bagley
Ontario, Canada
Offline TigreST
  • TigreST
« Reply #2 on: April 11, 2020, 07:27:12 PM »
Thanks Motorman.  I did an edit and put the G21-.46 picture in the opening post.  Yeah, looks to be a beefer unit on the RV model as you suggested.
Tony Bagley
Ontario, Canada
Offline Brian Hampton
« Reply #3 on: April 11, 2020, 07:44:10 PM »
Online RandySmith
« Reply #4 on: April 11, 2020, 08:48:12 PM »
That is  a  G40 in the  first picture, I still have tons of new parts for them,  BIG in pylon racing  back in the  70s
In The  G21 series  people  did use  the  G21 40  rear intake,  I have not seen a  46 in rear  intake
Offline Peter in Fairfax, VA
« Reply #5 on: April 11, 2020, 09:13:49 PM »
It actually does appear to be a .46, based on not only what is stamped on it, but also counting fins on the case.  One more than the .40, to my eye.
Offline Massimo Rimoldi
« Reply #6 on: April 12, 2020, 03:28:10 AM »
Good morning to all and Happy Easter.
The engine in the photo belongs to a series produced in the first half of the 1960s.  The series included a .40 Rat Racer, a .40 .46.  and .51 with 2 rings.  Attached is the scan of the advertising sheet of the time.
I have no idea what the suction and discharge times of the .46 are, so I don't know if it can be used in stunt.
Massimo
« Last Edit: April 12, 2020, 04:57:43 AM by Massimo Rimoldi »
Offline C.T. Schaefer
« Reply #7 on: April 12, 2020, 06:01:16 AM »
WOW!  Learn something new every day.
Online RandySmith
« Reply #8 on: April 12, 2020, 01:58:07 PM »
Massimo
Thanks  Massimo    That  engine  was  really popular  here in the  USA  as  a  G-40, They used it in  R/C Pylon  racer, in 40 size only .  That was  the  displacement limit.  That engine  also used the  ABC version of  loop charging, and  ST called  it  airfoil porting, 2 intake ports  1  exhaust
