  • July 17, 2025, 08:06:57 PM
Author Topic: Need to borrow. Saito .72 R/C Carb  (Read 1009 times)
« on: December 15, 2012, 12:33:39 PM »
Does anyone have a R/C carb for a Saito .72 that I can borrow?  I need to keep the rpm down for so many minutes of run time on initial break in.  Mine is the C/L version from the factory.
Thanks!
« Last Edit: December 16, 2012, 07:26:57 AM by Bill Little »
Re: Need to borrow. Saito .72 R/C Carb
« Reply #1 on: December 16, 2012, 02:50:54 PM »
Hi Bill; If it were me I would just block off half of the venture with a stick and run it on the rich side with a fairly good prop load that will keep the rpm down. On the old OS four strokes they said to run them wide open and use the needle to keep them at about 4,000 rpm. That also works well. Do check the valve clearance before running, and after running a while.
« Reply #2 on: December 17, 2012, 01:12:15 PM »
Hi Jim,
Thanks.  Looks like that is what I will have to do!
