  • June 20, 2025, 03:10:42 AM
Author Topic: Need help with fuel tank  (Read 1257 times)
Offline frank carlisle
« on: June 20, 2006, 08:37:28 PM »
When inverted the engine runs faster. The engine is inverted in the plane.
If I lay the plane on it's back which way do I move the tank to even out the engine run. UP?   DOWN? <=
Frank Carlisle
Re: Need help with fuel tank
« Reply #1 on: June 20, 2006, 08:48:43 PM »
up  away from the  motor  mounts
« Reply #2 on: June 20, 2006, 09:38:47 PM »
ahhh................thanks Randy.
My neck and back are killing me from bending over this plane for the last two weeks. Putting a shim under the tank is gonna be a cinch.
Frank Carlisle
