Engine basics => Engine set up tips => Topic started by: frank carlisle on June 20, 2006, 08:37:28 PM
When inverted the engine runs faster. The engine is inverted in the plane.
If I lay the plane on it's back which way do I move the tank to even out the engine run. UP? DOWN? <=
up away from the motor mounts
ahhh................thanks Randy.
My neck and back are killing me from bending over this plane for the last two weeks. Putting a shim under the tank is gonna be a cinch.
