  • June 23, 2025, 05:51:15 PM
Author Topic: Need a drop in replacement for a Fox 46 ABC BB  (Read 930 times)
Offline Jim Treace
  • 1979 600 Aerostar N79JT
« on: April 30, 2010, 12:57:47 PM »
I think I made a mistake. If possible, I need a drop in replacement for a Fox 46 ABC BB. I don't want to mess up the mounts.  I got the new Fox 46 ABC BB for a gift. It sat around for a while then I decided to build and put it in my scratch built Pat Johnson P51 profile. On the bench, the engine ran pretty good. Very easy to start. But once installed all I can get is a dry 2 or wet 4. I replaced the factory nva with a ST nva. Different plugs, tanks, fuel line, filters, etc. This helped a bit, but still no fun to fly. Sure does burn fuel and not smooth running. On one slow flight (bird mating season in TN), a bird attacked the slow flying P51, it stated a dogfight and the bird lost. So, I had to name the P51 "Birdkiller". No damage to the plane. The bird I think flew off and crashed.
Anyway, any suggestions as to what engine would fit these mounts??
Jim
Jim Treace
Ponte Vedra Beach, FL &
Paris, TN
AMA 855251 "Too soon we grow old...Too late we grow wise"
Offline Balsa Butcher
  • High Desert Flier
Re: Need a drop in replacement for a Fox 46 ABC BB
« Reply #1 on: April 30, 2010, 01:20:37 PM »
If it were the .40 a ST-46 would be a drop in. But it is a 46 so probably not. Just a thought: Contact Lew Woolard, his Silver Fox mods will make a good stunt engine out if it. I have only run his 40's but I hear he can rework the .46 as well... BTW, nice Mustang!  8)
Pete Cunha
Sacramento CA.
AMA 57499
Offline Jim Treace
« Reply #2 on: April 30, 2010, 01:46:51 PM »
I've tried a couple of times to contact Lew with no results and I was told that he was on medical leave, but this was several months ago. Anyone have current information?
Jim Treace
Paris, TN
Offline Marvin Denny
« Reply #3 on: May 01, 2010, 09:14:16 AM »
  Lew's computer is about as reliable as the weather if that is the way you tried to contact him.
  Try his phone if you haven't already.
  Bigiron
marvin Denny  AMA  499
