Engine basics => Engine set up tips => Topic started by: Jim Treace on April 30, 2010, 12:57:47 PM
Title: Need a drop in replacement for a Fox 46 ABC BB
Post by: Jim Treace on April 30, 2010, 12:57:47 PM
I think I made a mistake. If possible, I need a drop in replacement for a Fox 46 ABC BB. I don't want to mess up the mounts.  I got the new Fox 46 ABC BB for a gift. It sat around for a while then I decided to build and put it in my scratch built Pat Johnson P51 profile. On the bench, the engine ran pretty good. Very easy to start. But once installed all I can get is a dry 2 or wet 4. I replaced the factory nva with a ST nva. Different plugs, tanks, fuel line, filters, etc. This helped a bit, but still no fun to fly. Sure does burn fuel and not smooth running. On one slow flight (bird mating season in TN), a bird attacked the slow flying P51, it stated a dogfight and the bird lost. So, I had to name the P51 "Birdkiller". No damage to the plane. The bird I think flew off and crashed.
Anyway, any suggestions as to what engine would fit these mounts??
Jim
Title: Re: Need a drop in replacement for a Fox 46 ABC BB
Post by: Balsa Butcher on April 30, 2010, 01:20:37 PM
If it were the .40 a ST-46 would be a drop in. But it is a 46 so probably not. Just a thought: Contact Lew Woolard, his Silver Fox mods will make a good stunt engine out if it. I have only run his 40's but I hear he can rework the .46 as well... BTW, nice Mustang!  8)
Post by: Jim Treace on April 30, 2010, 01:46:51 PM
I've tried a couple of times to contact Lew with no results and I was told that he was on medical leave, but this was several months ago. Anyone have current information?
Post by: Marvin Denny on May 01, 2010, 09:14:16 AM
  Lew's computer is about as reliable as the weather if that is the way you tried to contact him.
  Try his phone if you haven't already.
  Bigiron
