  • July 17, 2025, 12:53:34 AM
Author Topic: Mystery of the Ring, Not Ringmaster  (Read 1945 times)
Offline frank mccune
« on: September 11, 2018, 02:20:27 PM »
       Hello All:
        Today I playd with my new reworked OS SF .46. This engine has a single ring.   I noticed that it had almost no compression before breakin and gained no compression after several 4 os. tanks or fuel.  In the past, I have had ringed engines that had great compression and some that had none even after being worked on by "experts."  The only way that the engines with no compression can be started is via an electric startere.  The engines with goof compression usually start with one flip by hand.
       The mystery is why do some ringed engines perform very well while others are duds? Here  is a list of ringed engines that are great:
       HP .40 Some stock and some with with rings by Mr. Bowman.
       OS Max .40S Ring fitted by Mr. Bowman.
       Testors .35 Used stock engine.
       In summery, what I am asking is why do some ringed engines work very well and others are real dogs even after being worked by experts? $$$$$$$$$$$$$$$$
      Yes, I am aware that I am living in the past with these ringed engines but that is going to change as soon as I get some ABC p&c sets for the HP .40 engines. I have contacted my psychriast for a session to help break me of my addiction to HP .40 engines. Update: He called and said that he does not treat people for addiction. AAAAAAAAAAAAAARRRRRRRRRRRRRRRRRRRRGGGGGGGGGGGGGGGG What to do? I have been clean and sober for many years but kicking the HP .40 habit has been the worse! LOL
        Suggestion and/comments?
        Tia,
        Frank McCune
     Thoughts and/or
Online Dave Hull
Re: Mystery of the Ring, Not Ringmaster
« Reply #1 on: September 11, 2018, 03:16:29 PM »
Frank,
I think you answered your own question, actually. If the performance issue is just cold compression for starting and ease of handling, then it is the fit. Your current example appears to be the OS 46SF which should have a single, standard ring. This is a tension ring which is part of the key to success. Other engines, perhaps your HPs(?) have a Dykes ring which is a different animal, and may have poor compression if flipped by hand but still run great. I've got a few K&Beast 40s with Dykes ring that can fool you.
Here are some thoughts:
Some experts are more expert than other experts. Proof of expertise is in the results. Everything else is just talk....
If you don't run an engine after you set it up, then you have to be really good at it to know that it will work fine. Lesser experts and more cautious engine builders who value their reputation would run it to make sure it will seat and not bind, and that the ring has acceptable temper and doesn't go "flat" after getting it hot. I got a couple of ringed engines from Frank Bowman, and he ran both of them after he completed his work. So he could be very, very confident that the setup was right.
If all the parts are really good--like factory new--and really to tolerance--and now you have to fit a ring to the engine, that takes skill but is not hard to succeed if you can make a ring to fit your parts. That means lapping it to width as needed and gapping it for leakage and to prevent seizing. Taking one out of a package and expecting it to work great is probably a little optimistic.
If you tell someone "to just change the ring" that can handcuff them. For example, if the installed liner is not round, then you can screw with the ring all day and be disappointed in the results. If the liner is ok, but the case bore is not round or is otherwise damaged, then the liner will conform to that and again, ruin your chances of a good fit. Engines that hit the ground hard may no longer have straight cases. I "repaired" an Enya that was like that.
If the metallurgy on the ring is not right, it's not going to be a good performer. On a tension ring (I think the SF falls in this category, but I don't own one...) the ring has to have a larger diameter than the piston, but not so large that the friction is too high, etc. I don't know how Frank was making his rings, but the ones that I made years ago were machined to a very specific larger diameter before they were slit. That gave me an initial tension setting. Making a ring the ID of the liner and then "opening it up to tension it" will almost certainly make it oval shaped. This doesn't work well in my experience. It is the last resort of the desperate, the night before a contest, with no spare rings in the drawer....
I suspect that a lot of engines are using fine-grained cast iron rings. (Meehanite)   Maybe there is something more modern being used.
Excessively rough finishes on the ring or on the cylinder will prevent it from ever seating. Not prepping the cylinder before putting in the new ring seems like a waste. At best, the results would likely be hit and miss.
I found that pinned rings are harder to set up. Harder to measure the gap accurately.
Trying to run a chromed ring on a chromed cylinder used to be a fool's errand unless someone has invented some magic. For example, if the fit was so perfect that it did not need to wear at all to seat--that would be magic!
You probably know all this already, being a ringed engine man. And I didn't really help you. But we can always commiserate, right? That doesn't cost extra....  And that is good therapy.
PS--My last "project engine" was a friend's K&B 61. The last engine man abused it for sure, but probably the one before that did some fundamental damage to the case bore and the liner. I did what I could but after getting rid of the pliers marks on the liner flange and the huge burrs on the inside of the case from a broken ring (improper disassembly) I will probably have to buy and fit a new ring. If the liner fully springs back to round after heat cycling it there is a chance....  I won't know until I run it. But right now, the compression is poor.
« Reply #2 on: September 11, 2018, 05:07:22 PM »
I can shed some light on this for you, many engines like the  HP 40  do NOT have good compression, NEW I have  done  over 100 of them and I can tell you it is hit or miss  for  NEW  HP 40s, first  with any engine  you need  a   ROUND Sleeve   and  a   ROUND ring,
Many people  do NOT want to pay for a  new  Sleeve  in a  NEW engine, and  it does  NOT matter  how many Bowman or  HP rings  you put in it, if the  sleeve  is not  round it will have  slack compression, They  also  DO NOT want to pay for  cases   extra rings  sleeves   or  any other  unusable  part
Another thing is the  HP 40 is  Pinned on the  intake side, this results in lower compression when flipped in the normal direction
Next is you have to have a  ROUND hole in the  case, I have seen many many engines that had an out of  round  case  distort  the  sleeve, This is especially  true with pressed in   sleeves.
This is  the main  REASON I had  many runs  of   ABC  Lapped  piston sleeve sets  made for the  HP40
I also made  many  OS 40 46 , OPS 40,   Thunder Tiger 36,  Os LA 40  , OS  SF 46   all  Custom made ABC or  AAC  engines  with  NO Rings
Most  ST 46 or  60  engines  Had  very good fits, except many were  TOO  tight, and needed  gapping  so not to  flat spot  and  destroy  the  ring in the  first few  runs
Older  OS  engines had, for the most part  good fits on the rings, but you did  see many that had  wide gaps
Testors had  Dykes  rings, and for  the most part  their  fits  sucked, You could get a  good fit but that was  rare
K&B  40s  and  61s  had a problem with many having  way to much  piston clearance  and  the rings had  too much gap  when brand  new.  People like  Stan Powell dealt with this by having the sleeve  chromed, making  the  BORE  smaller, Thus the rings  NOW fit better with small gaps, and in some cases  NO gap
Maybe the  very best  ring setup that a factory  did, was the   ABC-R  from HP in the somewhat rare  HP 40 Gold Cup ABC that had a brass chromed  liner and  a ringed piston
The best ring setups  we made  were thin rings ( more able to conform)  and  dual thin rings that were   PINNED  90 degrees  apart
When finding  you have  problems  getting a  great seal on a motor with a ring, check the  case bore, I have seen  over  2 to 300  with  the  case bore  lapped, or  hand sanded  out larger so the  press fit  would be  gone
Some used  220 grit  sand paper and the  fingers  to  do this
There  are  hundreds  of  other  things you can talk about  with  ring fits and  part problem, but these  are some  I have seen
« Reply #3 on: September 11, 2018, 06:02:48 PM »
      Hello Dave and Randy:
      Thanks so very much for taking the time to make very comprehensive replies.
       I was apprehensive concerning getting replies similar to yours as I imagined that I was opening Pandora's box when ringed engines were discussed.  The best option that I think that I have is to rid myself of all of the ringed engines that do not please me and replace them with engines that I will be happy to use.
      My flying mates and I have a few older ST ringed engines that run great out of the box.  These include G21-.46, G-.49 Sportsman, G- .51 and G -.56.  These are all box stock and could not run any better despite being old school design.  For some reason, the quality of these engines were/are great.  We also run some older ST .15, .19, .23 and .35 engines that still run perfectly even though they are of lapped design.  I have been told that the "newer" engines are much better and if that is true, we have come a long way in engine materials, fits and finishes.
        Be well,
        Frank McCune
Offline bob whitney
« Reply #4 on: September 11, 2018, 06:16:06 PM »
when I got back into flying in 1984 I bought a Tutor and a S/T 46 from Les McDonold at the OB hobbies. the 46 never did get any compression even after I good break in ,I bought a new ring ,gapped it and ran it rich for a good time. .again no comp .Les went in the back and brought out one of his Personal 46's .I ran that engine for 2 years before giving it to a new beginner and I know he ran it for a year and it still had good comp
the problem can be either the ring Or the sleeve.. the K&B 35 and 40's had poor ring control and many had a flat spot ,we called them D rings, u could put the ring in the sleeve and shine a light up the sleeve .if it was a D ring u could see daylight between the ring and sleeve',there was no fixing the ring ,most of the racers were using a Vic Garner ring that I believe  Stan found out about.
the problem with a leaking ring is that on the 2/4 break the conp leaks by the ring and go's lean and will not go back from 2 to 4
 enough Rambling
rad racer
« Reply #5 on: September 12, 2018, 08:08:44 AM »
     Hello Again:
     Just a few thoughts re. the above posts.
     I remember reading an engine report about  the new 1972 Rossi .15 engine.  It was the king of the hill for .15 engines in speed and expense.  The article took the reader through each manufacturing step for each part and the emphasis was placed on every FIT! Of course this cost more money to do this but the results were well worth the extra expense.
     In the pre Foxberg Racing, there was something like a 1 oz. Goodyear Race in the Wichita area that required a Fox .35 Stunt and a Goldberg profile stunt kit.  When our club tried this I was all in.  I spoke to a friend and he said, "Mail me your engine." When I received the engine it looked untouched inside and out but it would pull my porky Shoestring at 22 seconds for 7 laps.  Most other Fox engines were running 27 seconds for 7 laps and winning.  I called my friend and asked what he did to the engine and he replied," I just squared it up." He would no give any details! He later mentioned that having the piston and crank at 90 degrees made a huge improvement. How would one change this relationship in the engine?  This engine smoked everything it raced but after winning the feature one day,it puked the shaft and destroyed the engine.  Since then I have never seen a Foxberg racer that would do much better than 27/7 laps.
      Anybody have any idea as to what was done to this Fox .35 Stunt that was well used before he touched it to enable it to be so fast?  Fits???????
        Be well,
        Frank McCune
« Reply #6 on: September 16, 2018, 11:34:18 AM »
I had an old Atwood Champion that had some very slight scratches in the bore, and had little compression. I ran a 400 grit brake hone through it with a slight cross hatch. After running a few tanks of gasoline through it, the compression came back. Not real great, but easy to hand start. All of the old Anderson Spitfires I have that are ringed have super compression. They do have two rings, but seem to seal really well both forward and backward. Mel Anderson must have been very knowledgeable at making rings, or had someone who new how. I have never seen one of the 20 or 30 I have worked on that did not have good compression.
