  • June 17, 2025, 10:47:05 PM
Author Topic: Pipe setup  (Read 957 times)
Offline Paul Allen
Pipe setup
« on: February 06, 2012, 02:57:37 AM »
I have a 25Vf , Randy pipe and a MAC's header,I seem to remember reading that you leave the header the full length and
cut the pipe? As the header can handle the heat better is this correct still.
Also chasing a source of silicon tubing for the pipe it would need to 15mm ID, (16mm or 5/8" is not a tight fit.)
Re: Pipe setup
« Reply #1 on: February 06, 2012, 09:38:50 AM »
HI Paul,
Randy should have the silicon connector and a range to set the pipe initially.  We used to cut the header, it's cheaper, but the pipe doesn't like the heat if the header gets too short.
BIG Bear
RNMM/AMM
Re: Pipe setup
« Reply #2 on: February 06, 2012, 03:59:43 PM »
Cut the pipe  NOT the header, and if 5/8 is not really tight, don't worry it will be when you use the zip ties to cinch it down, we use 2 zip ties on either side
Offline Paul Allen
Re: Pipe setup
« Reply #3 on: February 06, 2012, 10:18:45 PM »
OK, thanks,Bill & Randy.
Re: Pipe setup
« Reply #4 on: February 07, 2012, 12:23:40 PM »
Hopefully I will be dealing with the same set up later this year.  An OS .25VF in an existing Ares.  I hope to do Billy's "operation". ;D
BIG Bear
RNMM/AMM
