  • June 26, 2025, 01:00:09 AM
Author Topic: Mufflers for older ST motors  (Read 2212 times)
Offline Carl Cisneros
« on: August 28, 2016, 09:58:59 AM »
Folks;
Any one know if any of the Mufflers guys (their names escapes me. old age here) make mufflers for the older
ST 46 and 60 motors that do not have the mounting ears on the cases?
G21-46 and a V60 chromed
thanks in advance.
Carl
Carl R Cisneros, Dist IV
Control Line RB
Re: Mufflers for older ST motors
« Reply #1 on: August 28, 2016, 12:31:07 PM »
Folks;
thanks in advance.
Carl
I have tongue mufflers that you can use with a small chrome radiator hose clamp , I may have a few untralite tube mufflers you can use on a ST st  51  46  with a strap
and I have a few new  Windy tongues  to use with a strap
Randy   678 407 9376
« Reply #2 on: August 28, 2016, 06:10:10 PM »
I will give you a shout either Monday or Tuesday.
Carl
Control Line RB
« Reply #3 on: August 31, 2016, 07:02:13 AM »
Randy;
I dug around the motor parts, ect. I have here at the house and found a couple tongue mufflers that I was able to adapt (going with a radiator strap)
for the 46. I also had a new unused tube type muffler for a K&B 61 that I also adapted for the ST 61 Chrome engine.
Both mufflers work nicely and do not come lose and stay right where I got them.
Thanks for the tip on the straps.
Carl
Control Line RB
Online Manuel Cortes
« Reply #4 on: September 04, 2016, 12:50:53 PM »
Hi all.
If it helps, Merco mufflers are a perfect fit for ST 46 - 60 engines. The ones I have used worked perfectly, better with all internal baffles removed.
Kind regards.
