  • July 05, 2025, 09:54:43 PM
Author Topic: Muffler Pressure...a note of caution...  (Read 1735 times)
« on: June 07, 2006, 07:44:10 PM »
Yesterday afternoon, a club member had his new ST G.51 out for the first runs and flights. On a TF "Tooter Too" (sic) ARF, but that's not important. Nor is the engine brand, actually.
First flight, after several ground runs, it started out very nice, but about halfway into the flight, it went lean. Not REAL lean, but peaked. After the flight, I retreived the model and noticed that the muffler gasket was hanging on the muffler pressure hose.
Hmmmmm....blown muffler gasket causes leak > causes reduced pressure to the tank > causes  f~ lean run.
Moral of the story is: IF you think you just gotta use muffler pressure, beware of this potential consequence. Also, skip the muffler GASKET. Lap both surfaces flat and smooth and maybe apply a very thin film of high temp silicon gasket stuff before assembly. Use better bolts than the slotted head screws that come with the engine. Any leak in the joint will at least be consistent, as long as the bolts stay tight. Make certain they do!
By the way, the ST G.51 is WAY more engine than the Tooter Too needs. And the (huge, ugly, heavy, complex, etc.) stock muffler, while a great candidate for the recycling bin, is very quiet. One redeeming quality, at least.   8) Steve
« Last Edit: June 07, 2006, 08:09:54 PM by Steve Helmick »
Offline Jim Thomerson
Re: Muffler Pressure...a note of caution...
« Reply #1 on: June 07, 2006, 08:38:15 PM »
And if you use too short a piece of fuel line to connect the muffler to the tank, it can vibrate off in flight with similar results.
Offline Glen Wearden
« Reply #2 on: July 08, 2006, 07:36:43 PM »
The Super Tigre muffler gaskets are worthless.  I have a GS 40, and I couldn't get a gasket to last through one flight.  Went the red RTV silicone route and no problems since.  Glen
Glen Wearden
« Reply #3 on: July 09, 2006, 07:20:47 AM »
Never used a muffler gasket.  Lap the surfaces if need be, but I've not had to do that either.  Some blue locktite on the muffler bolts won't hurt anything.
Offline Scott Jenkins
« Reply #4 on: July 10, 2006, 11:48:04 AM »
Better yet never use a muffler  ;D ;D ;D ;D
Old Racers never die or hear too good  n~
Scott
Scott Jenkins
AMA 43122
FAI F2C VOLUME 2 SECTION 4, 4.3.7
m) During the refuelling and the restart of the motor, and until the time when he releases the model aircraft, the mechanic must keep the model aircraft in contact with the ground by at least one point and with the centre line outside the flight circle. During that time the pilot must be crouching or sitting inside the centre circle. He keeps one hand on the ground and his handle and his lines as close to the ground as defined by the F2C panel of judges until the model aircraft starts again.
