Engine basics => Engine set up tips => Topic started by: Steve Helmick on June 07, 2006, 07:44:10 PM
Title: Muffler Pressure...a note of caution...
Post by: Steve Helmick on June 07, 2006, 07:44:10 PM
Yesterday afternoon, a club member had his new ST G.51 out for the first runs and flights. On a TF "Tooter Too" (sic) ARF, but that's not important. Nor is the engine brand, actually.
First flight, after several ground runs, it started out very nice, but about halfway into the flight, it went lean. Not REAL lean, but peaked. After the flight, I retreived the model and noticed that the muffler gasket was hanging on the muffler pressure hose.
Hmmmmm....blown muffler gasket causes leak > causes reduced pressure to the tank > causes  f~ lean run.
Moral of the story is: IF you think you just gotta use muffler pressure, beware of this potential consequence. Also, skip the muffler GASKET. Lap both surfaces flat and smooth and maybe apply a very thin film of high temp silicon gasket stuff before assembly. Use better bolts than the slotted head screws that come with the engine. Any leak in the joint will at least be consistent, as long as the bolts stay tight. Make certain they do!
By the way, the ST G.51 is WAY more engine than the Tooter Too needs. And the (huge, ugly, heavy, complex, etc.) stock muffler, while a great candidate for the recycling bin, is very quiet. One redeeming quality, at least.   8) Steve
Title: Re: Muffler Pressure...a note of caution...
Post by: Jim Thomerson on June 07, 2006, 08:38:15 PM
And if you use too short a piece of fuel line to connect the muffler to the tank, it can vibrate off in flight with similar results.
Post by: Glen Wearden on July 08, 2006, 07:36:43 PM
The Super Tigre muffler gaskets are worthless.  I have a GS 40, and I couldn't get a gasket to last through one flight.  Went the red RTV silicone route and no problems since.  Glen
Post by: Jim Thomerson on July 09, 2006, 07:20:47 AM
Never used a muffler gasket.  Lap the surfaces if need be, but I've not had to do that either.  Some blue locktite on the muffler bolts won't hurt anything.
Post by: Scott Jenkins on July 10, 2006, 11:48:04 AM
Better yet never use a muffler  ;D ;D ;D ;D
Old Racers never die or hear too good  n~
Scott
