  • July 18, 2025, 02:16:34 AM
Author Topic: muffler for McCoy 35 red head  (Read 2413 times)
Offline Richard Logston
« on: September 03, 2015, 02:41:40 PM »
I have a McCoy 35 Red Head that has vey good compression and shows very little use. I ran a lot of these back in the sixties with good success. I know the knocks on this engine and it's short comings. Question is has anyone made or used a muffler on this engine. I have a Do-Bro strap on muffler, but I would think you would not want to create too much back pressure or over heat it. Question, Has anyone ran this engine with a muffler?  I have made tongue mufflers from Do-Bro muffler extension stock in the past Also have made tongue mufflers from alum. stock just using hand tools. Thanks, Richard
Offline Scott B. Riese
  • Just a student of stunt
Re: muffler for McCoy 35 red head
« Reply #1 on: September 05, 2015, 01:26:59 PM »
YES. I run a muffler on 40 in my stuntwagon. Dave Royer runs one on his 35 in a warrior. You'll need to add some castor oil. Min. All castor content should be 25-30%. You engine will run hotter because of the back pressure. You may have to open up some holes in the muffler. Back in the good old days I also used a Tatone strap on muffler ...worked good!
Scott
Scott Riese
Portland, Oregon
AMA 528301
« Reply #2 on: September 05, 2015, 04:01:22 PM »
Scott, Thanks for your reply. I was expecting more input on this subject. Richard
Offline tom brightbill
« Reply #3 on: September 05, 2015, 04:20:37 PM »
Not much more to say beyond what Scott has posted except to ask him to make one for you  ;).  He made one for my early 60's 35 RH, a piece of art.
AMA 34849
« Reply #4 on: September 05, 2015, 04:26:24 PM »
  Do a search on the forums, I think here in the engine section, and some one did an excellent thread on how to make a muffler out of sheet aluminum using only hand tools, and I think he uses a .35 RH in the photos. Really a neat and ingenious method that I want to try some day. If it's not, it should be one of those threads pinned to the top of the section. Check it out.
  Good luck and have fun,
« Reply #5 on: September 05, 2015, 06:21:13 PM »
  I finally said the magic words in the search function and found it. Try the link below;
    http://stunthanger.com/smf/index.php/topic,7960.0.html
   If you have a Dubro universal muffler, you can reduce the back pressure by turning the set screws on the exhaust to open the spring some to allow more exhaust flow. I think that is how they worked. The biggest thing to watch with strap on muffler is getting the strap too tight and distorting the cylinder, affecting the engine run. With a little experimentation, you should get a nice run on a Red Head with a muffler installed.
« Reply #6 on: September 05, 2015, 09:35:46 PM »
OK, now we are getting a little action on this subject. I will try to post my home made mufflers, one is for a OS 40 FP and the smaller one is for an Old Fox 19. These are made with hand tools only, Maybe a little rough but should work for what they are intended for. The holes are just a starting point, may need more, only testing will determine that. Richard
« Reply #7 on: September 05, 2015, 09:53:34 PM »
Dan, Thanks for the link on mufflers, very informative and educational. Richard
