  • June 20, 2025, 05:26:56 PM
Author Topic: Thunder Tiger CL Parts  (Read 1277 times)
« on: September 08, 2015, 07:09:09 PM »
Does anyone know where I can obtain a CL venturi and needle valve assembly for a TT 46 pro?
Offline Geoff Goodworth
Re: Thunder Tiger CL Parts
« Reply #1 on: September 08, 2015, 11:04:44 PM »
If you are talking about the GP range, the pinch bolt is M4 so an ST NVA or clone will fit if you choose to use a true—sprinkler—venturi.
Scott Riese made some excellent venturis for my GP 25s and GP 50s and Randy Smith can supply them as well. Then it's a straight bolt-in conversion.
« Reply #2 on: September 08, 2015, 11:36:15 PM »
yours is done  if that is what your needing, I can ship it at any time
« Reply #3 on: September 09, 2015, 07:44:13 AM »
Wow Randy, I didn't know you were working on one. I need 3 sets. If 3 is too much, I can take 2 and swap between motors if that is better for you.
