  • June 21, 2025, 08:56:28 PM
Author Topic: Replacement for a Fox 59 needle valve assembly  (Read 1020 times)
Offline Bill Calandrella
« on: June 11, 2015, 09:09:51 AM »
I would like to know what needle valve would be the best replacement for the OEM needle and spray bar on a Fox 59 (short shaft).  The outside dimension of the venture is 5/8 of an inch.  I contacted Eric Rule and he suggested the ST setup for a Fox 35 replacement.  That is much to short.  I would appreciate your advice on this.
Online Robert Zambelli
Re: Replacement for a Fox 59 needle valve assembly
« Reply #1 on: June 11, 2015, 06:59:37 PM »
Bill - you may be able to use the NVA from an ST 60.
