  • June 20, 2025, 11:07:10 AM
Author Topic: Merlin ultra light?  (Read 1271 times)
Merlin ultra light?
« on: December 23, 2006, 06:26:25 PM »
Randy,
Just noticed you mentioned the "merlin" ultra light .40.  Is that an enhancement of  the engine I got two or three years ago or the same animal?
Ted
Offline Greg L Bahrman
Re: Merlin ultra light?
« Reply #1 on: December 23, 2006, 08:50:28 PM »
This is what my PA40 Ultra Lite looks like. If it helps?
From another post by Randy,
The PA 40 is the same size case and mount diminsions as the 51, 61, 65.
 They can all be  interchanged, with each other. And ALL PA engines run very well on a pipe or muffler.
The new Merlin series PA ultra lite 40 is a much smaller size case and will go into many classic airplanes as well as modern stunt ships.
It is more the size of a 35 engine.
Weighs about the same as an Aero Tiger or Magnum 32, 36  (8oz.)
The PA 40 Ultra lite has the same mounts as an older ST 35, 40, 46, but is longer on the nose. This allows you to make a very sleek cowl without using a prop shaft extention.
Click on picture to see it larger.
« Last Edit: December 28, 2006, 06:03:34 PM by Greg L Bahrman »
Greg Bahrman, AMA 312522
Simi Valley, Ca.
Online RandySmith
« Reply #2 on: December 24, 2006, 01:11:58 PM »
Randy,
Ted
Hi Ted
If It looks like the photo  above it is a Merlin series Engine, they are the same as the one  you got a couple of years ago ,
The new 100% all new motors designed strictly 100% for CL Aerobatics are the  Merlin series, PA 40 UL  and the 75 and 85 series Merlin PA engines
and Happy Holiday
