  • June 20, 2025, 12:48:39 PM
Author Topic: V case St 60's & 56  (Read 964 times)
Offline Gordon Tarbell
V case St 60's & 56
« on: December 23, 2006, 08:44:13 AM »
Are the piston and liners interchangeable on these. I have two 60's one with ears and one with out and a 56 no ears. Are the P&l the same between the two 60's and can I bore the 56 case to take 60 P&L sets? I have two Bristunt ABC P&L sets to use.
Gordon Tarbell AMA 15019
Re: V case St 60's & 56
« Reply #1 on: December 23, 2006, 03:39:51 PM »
HI Gordon
There were so many differant pistons of varying features, pin placements ,ring types, etc.  and liners of differant thicknesses that you will most likely have to get a set of calipers and measure to know for sure
