  • July 09, 2025, 10:50:57 PM
Author Topic: McCoy mix  (Read 1136 times)
Offline Phil Coopy
McCoy mix
« on: March 04, 2008, 05:07:45 PM »
If I want to run a McCoy 35, what % oil content should I use to be safe. Right now I'm running Fox 35's on 28%. I tried some in the McCoy and it runs pretty good. I'm gonna try the McCoy in a VECO Thunderbird.
Phil
Offline Jim Oliver
Re: McCoy mix
« Reply #1 on: March 04, 2008, 05:25:55 PM »
Hey Phil,
What I have seen suggested for the McCoy is the same as for the Fox 35, 25-29% castor.  I feel sure you will get further input on this from those with more experience in this area.
Cheers,
Jim
Jim Oliver
AMA 18475
Re: McCoy mix
« Reply #2 on: March 04, 2008, 05:30:01 PM »
28% Mostly castor should be fine in the McCoy. I would not go less than 25% castor, and about 5 or 10% nitro seems to work fine. I generally run 5% nitro in the McCoy 40's, and 10% in the 35's.
Offline Phil Coopy
Re: McCoy mix
« Reply #3 on: March 05, 2008, 03:28:02 PM »
thanks folks.
Phil
Offline Garf
    • Hangar Flying
Re: McCoy mix
« Reply #4 on: March 17, 2008, 02:36:29 PM »
Treat this thing just like a Fox 35 and it will work just fine.
Re: McCoy mix
« Reply #5 on: March 17, 2008, 06:36:58 PM »
I agree with what has been said, totally.  As of late, I have not been able to get 29% all castor, but I can get Sig 10% nitro and 25% all castor.  I add an ounce of Randy's Aero 1 oil per gallon and it works great for me at this altitude, etc..
I use a Red Head 29 in OTS and a Red Head 40, 35, and 19 at various times in Classic.
Re: McCoy mix
« Reply #6 on: March 17, 2008, 08:24:52 PM »
If you want custom mixed fuel at "normal" prices per gallon call Randy Rich at 713-661-5458.   Randy will mix anything you want and not charge you an arm and a leg.  He hauls my years' supply of fuel to the Toledo show each year and I've used nothing but since 1990 with great results.  (Some of that has been 28% all-castor.)  And remember, he's cheap by comparison to many of the others.
Blessings,
Will
Re: McCoy mix
« Reply #7 on: March 18, 2008, 07:12:26 AM »
Blessings,
Will
Thank you for the phone number, Will!
