  • June 20, 2025, 11:30:16 PM
Author Topic: Magnum 36 vs Thunder Tiger 36?  (Read 1308 times)
Offline Ken Deboy
    • Silk and Dope
« on: March 09, 2007, 09:52:07 PM »
How do these engines compare with each other?
thanks,
There is a fine line between "hobby" and "mental illness"
Re: Magnum 36 vs Thunder Tiger 36?
« Reply #1 on: March 09, 2007, 10:45:51 PM »
thanks,
My square head Magnum is a touch lighter, and friendlier for a stunt run, when both are in stock trim.   Plus they are a little cheaper.  I see many more of the Magnums in use for stunt than the TT's.
Now if you want the "Mac Daddy" 36 size stunt engine, get an Aero Tiger.  A specially timed AAC version of the TT 36 built by Randy Smith.  One of the all time great stunt engines.
I understand Richard makes an AAC Ro-Magnum, but I have never seen one in use around here.
Bill <><
« Reply #2 on: March 09, 2007, 10:58:18 PM »
thanks,
Hi Ken
The Thunder Tiger is a much much higher quality motor, the fits are  always much better on the Thunder Tigers ,both Magnum and TT 36 can be good stunt engines, the Magnum is a little cheaper but suffers from terrible stock bearings, Both engines have to be converted over to CL, as they are only made in R/C form.
The Thunder Tiger will normally last longer than the Magnum, and has a bigger front bearing and the same head bolt size as an OS 46 LA instead of the tiny 2.5mm that the Magnum has.
I sell the Thunder tigers about 2 to 1  over the  Magnums, however  both of these  are  a really great buy, for what you get.
I have built hundreds of both of these engines, and if you go with the Magnum it would be a good idea to put in decent bearings at the start, you will make for a longer lasting stunt engine, and they are priced really low, so you can do that very easy and still not have much money in a very good  stunt engine, for me  this is a  much better buy for your money than a 40LA or equivilent plain bearing engine.
As a side note  Dondi garrison won 3 NATs championships, with a Thunder Tiger 36 /VECTOR 40  combo ,and put over 1200 flights on the motor before he just completely wore it our.
