  • July 08, 2025, 12:41:46 AM
Author Topic: OS LA25 needle valve options?  (Read 1435 times)
Offline jeffindayton
  • AMA 166779
« on: July 11, 2006, 07:26:48 PM »
I would like to know about optional needle valve assemblies....Mr. Pratt has something different on his Primary force with the LA 25.....could someone enlighten me.
I believe the photo can be seen at, from 2000 nationals???
http://clflyer.tripod.com/images/Photos%202002/P1010021.jpg
Dayton, OHIO USA
Smooth Flying...not yet
Jeff Huntsman
Offline Leester
Re: OS LA25 needle valve options?
« Reply #1 on: July 11, 2006, 08:45:12 PM »
It's what is on mine, but I just checked the box and mine says LA not LAS. So my guess is it's a ST NVA. Funny I bought mine new from ,Oh it doesn't matter.
Leester
ama 830538
Alan Hahn
« Reply #2 on: July 11, 2006, 09:22:56 PM »
Sort of looks like a ST assembly or a close variant. There is nothing special about the spraybar you use. I scored a lot of ST spraybar assemblies from Tower Hobbies a couple of years ago, so that's what I use. At that time I was running thru spraybars quite fast (a result of learning outside maneuvers and engine quittings while inverted--tough with a profile). As long as you can deal with the slightly wider width (which restricts the venturi over an OS spraybar assembly). Compared to the ~$15 cost of an OS assembly, I can live with drilling out the crankcase to push the spaybar thru. If you need the power lost in the restriction, you can always drill open the venturi a little more.
  • AMA 166779
« Reply #3 on: July 13, 2006, 04:43:16 PM »
ST as in SuperTigre and NVA as in???
Dayton, OHIO USA
Jeff Huntsman
« Reply #4 on: July 13, 2006, 05:03:50 PM »
ST=Super Tigre
NVA= Needle Valve Assembly
Needle, spray bar w/nut, and needle locking nut in the case of the ST.
