  • July 08, 2025, 02:34:53 PM
Author Topic: Looking for a NVA  (Read 3384 times)
Offline nathan Metzner
Looking for a NVA
« on: September 11, 2010, 10:22:48 AM »
I have an older O.S. Max .15 She is older probably 70's. It's never been run. It's set up for R/C and I'm wanting to switch it over to control line. Here's my problem. I took the ventrui and NVA out of my newer LA and it won't fit the Venturi O.D. is too small and the NVA O.D. is too big. The part numbers for the correct NVA and Venturi are 21512205 Venturi and 21511000 NVA. I'm kinda stuck here because O.S. doesn't support engines this old. I've called a few older hobby stoes to see if they have any NOS stuff but no luck. Any help would be seriously appreciated.
Thanks Nathan
Nathan, New guy, Newbie, Youngster, Pleeb, So on and so on
Re: Looking for a NVA
« Reply #1 on: September 11, 2010, 10:25:49 AM »
Almost forgot the correct NVA O.D. is .120
Offline dennis lipsett
« Reply #2 on: September 11, 2010, 10:57:15 AM »
There is a dealer on ebay by the name of robinare that specializes in out of production parts. He might be ableto help you.
Dennis
« Reply #3 on: September 11, 2010, 11:13:01 AM »
Thanks dennis I'll try that out
« Reply #4 on: September 11, 2010, 11:18:18 AM »
I just took a look and for some reason that seller is not listed. Ughh Ebay can be goofy I'll try again later
Offline Leester
« Reply #5 on: September 11, 2010, 12:06:17 PM »
I'd check with Randy Smith or Lee Machine, Both are in the vendors corner
Leester
ama 830538
Dwayne
« Reply #6 on: September 11, 2010, 01:18:57 PM »
Just do a search on ebay for needle valve there are all kinds of them I just bought one for a OS 10 and I know I saw a I 15 there as well.
« Reply #7 on: September 11, 2010, 02:20:37 PM »
Yeah I've tried Ebay all I can find is FP and LA parts. Mine being different I was hopeing somebody might know something that'll work. I can drill the block but the fp la venturi won't work either.
« Reply #8 on: September 11, 2010, 05:50:22 PM »
That's probably 3mm, 0.118 inches.
Now, if you can just find one...
« Reply #9 on: September 11, 2010, 06:08:11 PM »
I mounted the engine to the plane and made a linkage for the rc carb to stay open. She went through two tanks of fuel so far in the break in. She sounds real good. I can't wait to be able to needle it and see what she's got.
Online kenneth cook
« Reply #10 on: September 11, 2010, 06:43:57 PM »
         Nathan, is this the engine with the black steel fins or the all aluminum case? I may just have a venturi for that engine if its the steel fin version. I will have to double check. I don't have the spray bar or needle though. Ken
« Reply #11 on: September 11, 2010, 08:20:05 PM »
Nope she's aluminum. I appreciate you trying though. I'll post a picture of her.
« Reply #12 on: September 11, 2010, 09:52:18 PM »
Dennis
Sorry I got the name wrong. Try Robair 81. He is from Canada and has an extensive list of parts. If you don't find it contactt him directly. he might be able to help you.
Dennis`
Oh the needle valve assembly from the OS15 steel fin should fit.
« Reply #13 on: September 12, 2010, 05:34:07 AM »
Kenneth, If you stumble upon that venturi and you have time could you measure the O.D. were it fits in the block? This is were my LA venturi was wrong the OD was too small
Offline Marvin Denny
« Reply #14 on: September 12, 2010, 11:22:12 AM »
  I'll check the junk barrel !   I won't have the venturi, but may have the NVA.
  Bigiron
marvin Denny  AMA  499
« Reply #15 on: September 12, 2010, 02:29:34 PM »
Marvin, I would really appreciate it. Thank You
Nathan
« Reply #16 on: September 12, 2010, 08:09:24 PM »
  Nathan, I checked and no luck.  I really thought I had one, but I couldn't find any.
 Sorry
  Bigiron
« Reply #17 on: September 13, 2010, 02:34:26 PM »
I appreciate you looking Marvin. I'm sure I'll find one somewhere.
« Last Edit: September 13, 2010, 04:47:19 PM by nathan Metzner »
« Reply #18 on: September 13, 2010, 04:46:20 PM »
LOL nope I'm kinda ignorant of the hierarchy of control line flying. I'll edit my post. No disrespect was intended.
Offline Balsa Butcher
  • High Desert Flier
« Reply #19 on: September 13, 2010, 06:16:49 PM »
I suspected as much. Welcome to the club. Good luck with your search, wish I could help.  8)
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #20 on: September 14, 2010, 02:44:07 PM »
Thanks.
« Reply #21 on: September 19, 2010, 01:31:49 PM »
Do you have a carburetor?  You can measure the OD of that if you have calipers.
Alternately, if you know someone with a drill index full of letter-size (or metric) drills, you can try them out in the bore (use the back side of the drill if they don't taper) to get size estimate good enough to identify the thing.
« Reply #22 on: September 19, 2010, 03:51:28 PM »
I postaed the o.d. Of the NVA the venturi I did not. I just broke the nva off the carb yesterday. So now I have to get something lol dag gum inverted flight. I still don't have the knack of it. The planes over at my dads right now but I'll post the size of the venturi opening of the block when I get over there.
