Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
July 29, 2025, 01:06:14 AM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
ST NVA for Fox .35
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: ST NVA for Fox .35 (Read 11743 times)
Paul Taylor
25 supporter
Trade Count:
0
Admiral
If God is your Co-pilot - swap seats!
ST NVA for Fox .35
on:
February 11, 2006, 08:40:43 PM »
Some one gave me a new ST NVA and on the bag it says for ST .51 or Fox .35.
I pulled my Fox NVA and installed the new ST NVA.
Problem:
ST NVA seems a little lose in the hole. And when I tighten the nut down I run out of threads and the NVA is not tight. Seems too long.
I put the Fox NVA back in. Last question. The Fox NVA has two holes in it. Do I point the hole up and down or point them front and back?
Paul Taylor
Logged
Trade Count:
0
Admiral
AMA78415
Re: ST NVA for Fox .35
Reply #1 on:
February 11, 2006, 08:54:19 PM »
Hi Paul; The Super Tigre spray bars generally have a brass washer with them to take up the slack for Fox 35's. As far as the Fox spray bar, the holes go front and rear so that you can't see either on when looking down in the ventura.
Logged
RandySmith
Administrator
Trade Count:
0
Admiral
Welcome to the Stunt Hanger.
Reply #2 on:
February 11, 2006, 11:38:48 PM »
Hi Paul
It also sounds like you have a 40 size ST NVA instead of the bushing case 35 size.
There was at least 3 sizes that ST made in that NVA
You can do as the previous post said and use a washer as a shim
Logged
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
ST NVA for Fox .35
