  • June 21, 2025, 08:27:00 AM
Author Topic: LA46 drive washer, help  (Read 1203 times)
Offline Steve Agrella
    • Steve Agrella Photography
« on: June 03, 2015, 09:07:23 PM »
I made a mistake and made my nose cowl too long dang it, I put the the spinner plate and prop on and crap its aprox .010 too long, the plane is finished, any suggestions to shim the drive washer.015 without having to sand the finish.
You guessed I'm a rank amateur, wanted a nice tight fit, got it too tight.
Offline dennis lipsett
Re: LA46 drive washer, help
« Reply #1 on: June 03, 2015, 10:00:52 PM »
Take a piece of course sandpaper and make a washer out of it. Placed on the shaft it should be thick enough to give you the clearance that you need . I've used this fix a few times over the years.
Dennis
Offline Chris Wilson
« Reply #2 on: June 04, 2015, 12:38:59 AM »
My personal preference would be for a D washer behind the prop driver - fiddly to make the centre cut out though.
MAAA AUS 73427
« Reply #3 on: June 04, 2015, 05:44:35 PM »
Worked like a charm, thanks very much
