  • June 16, 2025, 06:40:49 AM
Author Topic: Tower .46  (Read 2905 times)
Offline James Holford
Tower .46
« on: March 05, 2018, 09:41:06 PM »
Whats yall thoughts bout a Tower .46? Got one quite cheap today. Curious on peoples thoughts on using them for stunt.
Jamie Holford
Baton Rouge Bi-Liners
Lafayette, La
AMA #1126767
Offline GERALD WIMMER
    • Auckland Free Flight Club
Re: Tower .46
« Reply #1 on: March 06, 2018, 03:46:29 AM »
Hi Jamie
Looks like another OS45 FSR clone like the Magnum 45, ASP 45 , Thunder Tiger etc. I'm sure with a light weight muffler 6 mm venturi and low pitch (11.5x4) it would run real fine! It does need a good seal so as long as compression is fine it should be worth adapting to C/L Stunt.
 Unless an all out racing or ducted fan engine you can normally adapt them fine to stunt , only have to watch the weight especially with factory mufflers but if you build tail heavy their is some good nose weight .  ;)
Regards Gerald  #^
Re: Tower .46
« Reply #2 on: March 06, 2018, 03:48:48 AM »
Hi Jamie
Regards Gerald  #^
Jamie Holford
Lafayette, La
AMA #1126767
Offline Tim Chenevert
Re: Tower .46
« Reply #3 on: March 06, 2018, 04:25:14 AM »
James, that engine needs a plane....Tim
AMA 179681
Re: Tower .46
« Reply #4 on: March 06, 2018, 04:34:05 AM »
Lol right.
Jamie Holford
Lafayette, La
AMA #1126767
Re: Tower .46
« Reply #5 on: March 06, 2018, 05:49:30 PM »
All these white men look the same ( Chinese Joke  :P)
a MEGATECH ! 40 . Yrs looks a bit like the Magnum 46 / 51  that were popular .
Think the OS theyre all piratyed from is the FS or SF .
Offline Manuel Cortes
Re: Tower .46
« Reply #6 on: March 07, 2018, 12:13:09 AM »
Hi all.
Matt, it seems to me the same as my LEO 46, a chinesse copy of the OS 46 SF (the same for the 40), with true ABC piston liner assembly (bought 2 of them some years ago in Hobbiking at 36 USD each...... ~^ ~^ ~^
The LEO 28 btw is a good powerplant for Super Clown or Rigmaster type models.....
Reasonably well made, the worst part are the bearings, but this is easy to solve.
Almost impossible more for less..... ;D ;D ;D ;D
Kind regards.
Manuel.
Offline Skip Chernoff
Re: Tower .46
« Reply #7 on: March 08, 2018, 07:55:33 PM »
I have two Tower Hobbies 40s set up for stunt,and both run beautifully.
Re: Tower .46
« Reply #8 on: March 17, 2018, 08:32:44 PM »
     The Leo/Brat 28 was one of the engines I tried in the "small engine" experiments and it is indeed completely usable for our purposes, and 35-sized profile models, using the formula. I think it liked the Tornado 10-4 and APC 10-3, but that was a long time ago.   I know for certain that at least one National Champion started out with a Leo 28 on a UKey 35 (2006 Senior National Champion Paul Ferrell), because I think he ended up with my Leo 28 thrust washer, when his got dropped in the gravel and lost at the Alameda field.
Re: Tower .46
« Reply #9 on: March 17, 2018, 08:37:48 PM »
Im undecided if I want to keep this Tower .46 for a stunt application or not. Not sure if its worth even fooling around with since I have a few .46LA's.
If anyone has experience running this engine Id like to hear some thoughts. The muffler it came with is huge!!!! Much bigfer than a stock .46la muffler. And the Tower.46 surely feels heavier than .46LA.
Jamie Holford
Lafayette, La
AMA #1126767
Re: Tower .46
« Reply #10 on: March 17, 2018, 08:38:18 PM »
The muffler differences.
Jamie Holford
Lafayette, La
AMA #1126767
Re: Tower .46
« Reply #11 on: March 18, 2018, 11:24:39 PM »
 S?P S?P or etc , as the njun weighs a Tonne .
Think It'd be a 4 inch pitch motor, not a 6, anyway .
Offline mike londke
Re: Tower .46
« Reply #12 on: March 23, 2018, 08:56:57 PM »
It's a bunch heavier. It's a ball bearing motor. I have 2 on RC planes and they are strong runners but I think too heavy for any .46 sized planes when you can use an LA. They do make tons of power though. One pulls my Kyosho Mustang at 85mph.
Re: Tower .46
« Reply #13 on: March 23, 2018, 08:58:24 PM »
Yep it weighs 12oz!!! Ill keep it as trade bait for a old engine or something.
Jamie Holford
Lafayette, La
AMA #1126767
Offline mike londke
Re: Tower .46
« Reply #14 on: March 23, 2018, 09:00:01 PM »
It is an excellent RC motor though.
