  • June 23, 2025, 11:59:56 PM
Author Topic: LA40 in place of a OS35 s ?  (Read 1083 times)
Offline phil myers
« on: June 12, 2013, 01:14:03 PM »
Just wondering if an LA40 (or FP40) can be fitted where an OS35s is currently? I've  been given a 3 line model  to play with but the OS lacks power. The plane is only going about 50mph and on anything but calm days its not worth the risk.. Its a 50" wingspan and built up fusalage, I don't want to cut away the nose area to put in new bolts..any ideas please.
Phil
Offline Duke.Johnson
Re: LA40 in place of a OS35 s ?
« Reply #1 on: June 12, 2013, 01:27:12 PM »
I think the 35FP and the 40 LA and FP are the same. My son runs a 40FP in a 50in wing with no problem in the wind.
Offline Balsa Butcher
  • High Desert Flier
« Reply #2 on: June 12, 2013, 01:50:33 PM »
Yes, the bolt pattern on the OS35-S is the same as the FP and LA. Case is shorter though, not a problem. Brodak 40 will also fit. 8)
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #3 on: June 12, 2013, 01:58:43 PM »
Tower 40 also
  • High Desert Flier
« Reply #4 on: June 12, 2013, 03:21:53 PM »
...and if you need even more power and OS-46 LA will also fit. 8)
Pete Cunha
Sacramento CA.
AMA 57499
Offline phil myers
« Reply #5 on: June 13, 2013, 09:23:10 AM »
Thankyou to all
Phil   :)
