  • June 23, 2025, 04:45:19 AM
Author Topic: Throttle control bellcrank for a Mosquito.  (Read 743 times)
Offline Timothy Payne
  • Mr Payne
  • Classic Racer
« on: June 12, 2013, 08:45:44 PM »
Can anybody advise me/give ideas as to the feesability of using a 3-way bellcrank for twin throttle-control?
Has anybody tried this with two motors or even know if it's ever been done?!!!
Timbo
Offline Balsa Butcher
  • High Desert Flier
Re: Throttle control bellcrank for a Mosquito.
« Reply #1 on: June 12, 2013, 09:46:34 PM »
Many have done this, sometimes even successfully. Brodak sells a kit (SKU BH-400) to adapt their 3 line bellcrank for a twin engine set-up. It was specifically designed for their Grumman Tigercat profile scale/carrier but could be applied to your project. You may want to order the Tigercat plans (or kit)  to see how the linkage is setup. 8)
« Last Edit: June 12, 2013, 10:22:42 PM by Balsa Butcher »
Pete Cunha
Sacramento CA.
AMA 57499
