Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
June 17, 2025, 07:39:48 PM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
LA 46 Venturi Set-Up
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: LA 46 Venturi Set-Up (Read 1032 times)
Peter in Fairfax, VA
24 supporter
Trade Count:
0
Admiral
on:
May 05, 2019, 09:23:51 AM »
So I have this full bodied stunter that fits an O.S. LA 46. Just bought a used engine off eBay, which should arrive late this week. It's an R/C. Plan to sell the carb / remote NVA on eBay, because it would just be clutter for a CL person. Now I need an NVA / Venturi.
Though I looked at Lee Machine, I liked the offering on eBay from shtterman which includes not only an NVA, but also a 4mm bit to drill the case. I plan to stuff a rag in the intake, tape closed the exhaust, invert the engine and drill with a vacuum cleaner running below, then flush the engine.
The supplied NVA is from Enya. Are they any good? If it doesn't work out, I'll see if I have a SuperTigre, Harry Higley or something better.
https://www.ebay.com/itm/OS-FP-LA-35-46-C-L-VENTURI-AND-ENYA-TYPE-NVA-NIP-DELRIN-6-5-MM/223473017798?hash=item340807a3c6:g:H7gAAOSwt5hYbuBP
Logged
Carl Cisneros
Trade Count:
0
Captain
Re: LA 46 Venturi Set-Up
Reply #1 on:
May 05, 2019, 11:57:40 AM »
Petter
read the message i just sent you
Carl
Logged
Carl R Cisneros, Dist IV
Control Line RB
Carl Cisneros
Trade Count:
0
Captain
Reply #2 on:
May 05, 2019, 12:14:22 PM »
I have also used the NVA that Bobby sells and they work a treat for me.
used on: LA46, 35S, H60 OS, Enya motors, K&B, HB and HP motors.
Carl
Logged
Control Line RB
25 supporter
Trade Count:
0
Admiral
Reply #3 on:
May 05, 2019, 03:09:07 PM »
shtterman also sells a needle valve assembly that does not need drilling on an OS engine. I think he had Enya make some to OS specs for him. A better option of you do not want to drill your engine.
Logged
EAA 1038824
Allen Eshleman
Trade Count:
0
Captain
Reply #4 on:
May 07, 2019, 06:33:02 PM »
I drilled one on a drill press with a vise holding it. That was my first time. Worked like a charm for me. That was on an FP-25.
Logged
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
