  • July 12, 2025, 01:38:42 PM
Author Topic: LA 46 props  (Read 3788 times)
Offline Sean McEntee
LA 46 props
« on: September 13, 2012, 09:29:36 AM »
LA 46 owners, what's your prop of choice?
Offline mike donovan
Re: LA 46 props
« Reply #1 on: September 13, 2012, 09:39:05 AM »
I have been happy using the thunder tiger cyclone 11 x 4.5
Re: LA 46 props
« Reply #2 on: September 13, 2012, 09:40:51 AM »
Zinger Pro 11-4 or the carbon fiber Phelps prop from Tom Wilk.
Don
Re: LA 46 props
« Reply #3 on: September 13, 2012, 09:44:45 AM »
I have good results from APC 11.5 x 4 & APC 12.25 x 3.75.
some more infos here..
http://stunthanger.com/smf/index.php?topic=21156.0
« Last Edit: September 13, 2012, 11:15:30 AM by Joe Yau »
Mike Griffin
Re: LA 46 props
« Reply #4 on: September 13, 2012, 10:08:59 AM »
Sean I have used 11 x 4 and also 10.5 x 4.5.  All I use is APC and some of RSM's
Re: LA 46 props
« Reply #5 on: September 13, 2012, 11:33:13 AM »
Hi Sean!
There is a "List your set up" on the LA.46 in the engine section.  I'm going to start with the 12.25 X 3.75 APC.  I also am going to be running the OS .25LA/FP venturi.
BIG Bear
RNMM/AMM
Online Matt Colan
Re: LA 46 props
« Reply #6 on: September 13, 2012, 11:49:11 AM »
Majic 11.25-4.25 2 blade or majic 12-4.33 cut to 11 three blade.
Edited for typo
« Last Edit: September 15, 2012, 08:01:52 AM by Matt Colan »
Offline Gene O'Keefe
Re: LA 46 props
« Reply #7 on: September 13, 2012, 02:35:50 PM »
APC 12.25 X 3.75
Gene O'Keefe
AMA 28386
Online RandySmith
Re: LA 46 props
« Reply #8 on: September 13, 2012, 03:00:59 PM »
Majic 11.25-4.25 2 blade or majic 14-4.33 cut to 11 three blade.
Majic 12.24 x 4.25  , 12 x 4.33  3blade and  the majic 12.5 x 5 is very good on that motor
as is the Bolly 11 3/4 x 4 1/4 or Bolly 12.2 x 4.2
Offline Steve Hines
Re: LA 46 props
« Reply #9 on: September 13, 2012, 06:46:00 PM »
My brother just put up a new pathfinder with LA 46 stock muffler 11-5 APC 5.3 lap time great 2-2 break. Randy needle valve and back plate. Have not tryed other props it flew so good.
Offline Jim Oliver
Re: LA 46 props
« Reply #10 on: September 13, 2012, 06:58:54 PM »
Xoar 12x4 Beechwood
Jim Oliver
AMA 18475
Online Paul Taylor
Re: LA 46 props
« Reply #11 on: September 13, 2012, 09:18:58 PM »
Sean
I think a lot depends one the plane too. I have three planes and all three use different props.
Tutor. APC 11x4 Stock LA
ARF Nobler TT 11x4.5 (I think) Stock LA
Vector APC 12.25x3.75 Randy Smith LA
Offline Norm Faith Jr.
Re: LA 46 props
« Reply #12 on: September 13, 2012, 09:34:46 PM »
What Mike said.
Circlepilot   AMA9376
Offline Mike Keville
Re: LA 46 props
« Reply #13 on: September 13, 2012, 09:38:07 PM »
Tornado Plastikote 11-5.  (Okay, I'm yanking yer chain there.)
Generally, I'd pay a lot of attention to any suggestions from Randy Smith.
('nuff said.)
Re: LA 46 props
« Reply #14 on: September 14, 2012, 05:40:51 AM »
You will see what Paul Taylor says about his planes.   The LA .46 I have used has been on several planes.  Each plane used a different prop to get it to fly like I want it to fly.  So depending on the plane, you may have to try several different props.  But, if you lack experience, in my opinion, start with a Power Point 11 X 5 or Zinger 11 X 5.
Offline Bill Heher
  • Fix-it
Re: LA 46 props
« Reply #15 on: September 14, 2012, 06:18:13 AM »
I've found that at 5,000 feet in ABQ the RSM 11X6 works well on a LA .46 powered Tutor II ( it's closer to an 11 X 5 per someone who checked).
Same plane in Phoenix, lower altitude - I went down in pitch and up in Dia.   APC 11.5 x 4.25 worked well there
If I ever get my new TutorII done, I will see what works in hot humid Florida air at 70' above sea level.
Bill Heher
If it's broke Fix-it
Online Steve Helmick
Re: LA 46 props
« Reply #16 on: September 14, 2012, 11:44:03 PM »
Very true, Bill. Not only that, the rest of the setup matters a lot. When I flew with Larry Richards, Claude and George in Reno, I had brought a .46LA powered Forerunner. I'd used the .46 a lot in a Humongus with a MACS Muffler and an 11.5 x 4 APC...worked great with 10-22 and a .285" venturi. Same setup didn't work in Reno, and it wasn't the different airplane. It wouldn't spin up enough rpm to get the 1/4 wave tuned pipe mojo workin'. Tried an 11-5 APC, no magic. What worked was an APC 10.5 x 4.5. It might have worked with the 11.5 x 4, if I'd pumped it full of 25% nitro, but I didn't do that. The 10.5 x 4.5 worked very well. So, keep in mind that the venturi size (and spraybar dia.), muffler, altitude and the whole danged setup matters a lot. That's why so many wildly different props make so many different guys happy.  n~ Steve
« Last Edit: September 15, 2012, 11:49:30 AM by Steve Helmick »
Offline Phil Spillman
Re: LA 46 props
« Reply #17 on: September 17, 2012, 08:16:50 PM »
I have found that the Pro Zinger 11 X 5 works well for me with the RPMS set about 9200 on the ground! When I get above sea level I find that I must reset the needle for an optimum run!
Phil Spillman
Phil Spillman
Offline Aaron Little
Re: LA 46 props
« Reply #18 on: October 10, 2012, 08:41:53 PM »
Where does one obtain these?
Online Paul Taylor
Re: LA 46 props
« Reply #19 on: October 11, 2012, 06:31:22 AM »
Re: LA 46 props
« Reply #20 on: October 11, 2012, 06:40:38 AM »
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXBELC
Too easy.  I thought it would be some site that I had to translate from Chinese into English.
Tower makes it too easy!
Offline Joseph Patterson
  • AMA member- Supporter
Re: LA 46 props
« Reply #21 on: October 11, 2012, 10:01:31 AM »
     We are using APC 12X5 down here in La.w/hemi'd heads-  approx. .282 venturi's, and ST /RS NVA's, PM-10/22(11/11) fuel- Some use 12x5 EW wood props-Some run uniflow, some run pressure- both seem to do real good.
    Doug
