  • July 22, 2025, 02:57:39 PM
Author Topic: LA 46 Mods  (Read 1168 times)
LA 46 Mods
« on: March 05, 2020, 05:17:06 PM »
blank
« Last Edit: August 25, 2021, 06:17:04 PM by Motorman »
Offline Bootlegger
Re: LA 46 Mods
« Reply #1 on: March 06, 2020, 06:37:58 AM »
  I run mine completely stock, on 10/22 fuel and a 11.5 x 4 prop, and I like the way that it runs, about 4 oz of fuel at 8800-9200 R P M seems to work well, there is always the L A 46 column at the top of the engine set up, and you will see that I have changed from what I used to run, and I found it better to run stock, using a R Smith needle assy..
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Bootlegger
Re: LA 46 Mods
« Reply #2 on: March 07, 2020, 05:33:31 PM »
 Motor, It didn't run any worse than stock, but it used more fuel, we reduced the squish band to about 1/2 the original size and that was about it, if you read some more that might help, they ran well, but they did use more fuel..   10-22 is what we used, some of the guy's still use this set up...
Gil Causey
AMA# 6964
