  • June 17, 2025, 04:39:47 AM
Author Topic: PA 51 RE  (Read 1617 times)
Offline Paul Allen
PA 51 RE
« on: December 27, 2020, 01:56:13 AM »
         I have a Bolly 3 B 12 x 4.25 prop, cut down to 11"
would that be enough prop for a PA 51 RE /rear muffler set up?
Offline Alan Buck
Re: PA 51 RE
« Reply #1 on: December 27, 2020, 10:56:44 AM »
Paul   the 11x4.25 3blade may be a little small that is more for a 40.
 a 12x4.25 3 blade or 12.25 x 4.25  2 blade  is a good starting point
for the 51
ALAN E BUCK
Re: PA 51 RE
« Reply #2 on: December 28, 2020, 01:29:20 AM »
Yes, however , It will turn that prop easy, many use the same prop at 11.5 and  12 inches
Re: PA 51 RE
« Reply #3 on: December 28, 2020, 03:23:51 PM »
I like a 12-4 3 blade Brian Eather UNDERCAMBERED prop on my PA .51 (when flying on pavement), with the tips pitched up some.   y1 Steve
